patman Posted April 30, 2014 Posted April 30, 2014 Please please please, if anyone knows, if your facing the engine and your looking at where the loom comes out from the ecu (half way down in the middle of the back wall) what way should that black wire go to the left side (alternator side) or to the right ( gearbox side) almost finished my full engine rebuilt and for dear life cannot find the KS wire everything else is in place, got the ecu off today and the black wire is there pin 23 on the ecu but can't find it at all in the engine, and can only think there was never one on there as knock sensor it's self is there with a split wire in it, ooooor can I just do my own wiring from pin 23 to the knock sensor any info on this would be fantastic as it's driving me nutsThanks Pat 👍 Quote
patman Posted April 30, 2014 Author Posted April 30, 2014 Thankyou Richard mate might have to just do this seems now the engine is back together to much hard work trying to find it thankyou Quote
daniel_g Posted April 30, 2014 Posted April 30, 2014 The knock sensor wire comes out of the loom just under the thermostat housing area, you might have to peel back the loom until you find it if its been snapped. Its just a single wire. Quote
patman Posted April 30, 2014 Author Posted April 30, 2014 Thankyou so much Daniel mate I will be checking tomorrow why on earth it would come out that side who knows but will get on it tomorrow and see thanks a lot 👍 Quote
patman Posted August 12, 2014 Author Posted August 12, 2014 Old post I know but are you or anyone else 100% sure the knock sensor wire is coming where the thermo housing is, I just need to know what sensors it comes out with still having trouble finding it even though had my loom out yesterday and it's deffo in pin 23 the black wire 👍 Quote
Stu Posted August 12, 2014 Posted August 12, 2014 (edited) The knock sensor wire comes out of the loom by the injectors at the cam pulley cover end. Its normally a black wire shielded with blue insulating over the top. Look where the brake fluid level sensor wire/boost control wire/earths seperate off from the loom at that end of the head. You may need to take some of the wrap off to find it - they do break there quite often. If your fixing it make sure that the shielding continues right to the end by the plug and doesn't earth to anything at the engine end (its connected to sensor earth just up from the ecu). The wire down by the thermostat housing is the cat sensor or narrow band o2 sensor Edited August 12, 2014 by Stu Quote
daniel_g Posted August 12, 2014 Posted August 12, 2014 My loom has been pulled apart and re wired, thats why mine comes from that direction. Quote
patman Posted August 13, 2014 Author Posted August 13, 2014 The knock sensor wire comes out of the loom by the injectors at the cam pulley cover end. Its normally a black wire shielded with blue insulating over the top. Look where the brake fluid level sensor wire/boost control wire/earths seperate off from the loom at that end of the head. You may need to take some of the wrap off to find it - they do break there quite often. If your fixing it make sure that the shielding continues right to the end by the plug and doesn't earth to anything at the engine end (its connected to sensor earth just up from the ecu). The wire down by the thermostat housing is the cat sensor or narrow band o2 sensor You have nailed it on the head stu mate thankyou so much haven't checked yet as cars stored away at the moment but I had a funny feeling it came out of the injector end bit and I will get searching next time I'm down there, I only found all this out when I looked under the car months ago to see there was no knock sensor wire, then took the speedo cluster out only to notice there was never a bulb for the engine management light, (there is now, as I do everything how it should) funny thing was the car always ran good but thankyou stu for your help and you dan mate 👍 Quote
Stu Posted August 13, 2014 Posted August 13, 2014 No worries! I really should write a knock sensor 101 guide for people - too lazy Quote
patman Posted August 18, 2014 Author Posted August 18, 2014 Thankyou stu mate found it today it had obviously been snapped in half and was just sitting in the injector loom like you said black wire, with blue shielded cover on the top 👍 your a star mate Quote
