Item For Sale: ***CHEAP*** Levin Twinpots ready for Starlet
Item Condition & Description: used Levin twinpots in good condition for age have had a clean up and a paint job will require new pad clips are same bolt pattern as starlets will require disks to suit
theres tons of walk throughs do a search
for an extra £15 can chuck in some brand new OE spec pads
Price: SOLD
Payment & Shipping Details: Postage within the UK is free or collection is free
Edited by russ78
different discs needed coroĺla d4d for these as far as im aware
hmm
free bump anyways for cheap calipers.
Phil
cheap calipers these :)
i had to use the opel 280mm disks and get them cut down to size no spacers or longer studs required
what opel discs?
link an ebay link to the right set and could really help these sell!
Phil
Or if you use the discs off a 1.8vvti mr2/mrs with corolla single pot carriers it all bolts straight on. No machining, no spacers, no extended studs ;)
Courtesy of BiMotoMan ;)
No difference phil, same disc options for both. Only difference (if you like) is the levin caliper needs a tiny bit of trimming on the caliper bracket with a dremmel to clear the hub unless its already done. And phil use mk4 astra 1.7d discs. Just need to turn the inner bell housing by aprox .5mm to clear over the starlet hub. No spacer no longer studs.
The solution i gave above doesnt require any machining of the disk. It only requires the slight filing of the caliper which you have to don on them all.
Do you know which corrola carriers I need. Im gonna take these otherwise.
Thanks
