russ78 Posted May 5, 2014 Share Posted May 5, 2014 (edited) Item For Sale: Astra lathed Drilled/Grooved Discs Item Condition & Description: Brand New these have had all required lathe work to fit Celica ST165/82 single or twin pots so they fit a starlet perfect for upgrading brakesthey are 277mmPrice: £160Pictures:[Payment & Shipping Details: £10 posted or can be collected at japfest Edited May 5, 2014 by russ78 Quote Link to post Share on other sites
Turk Posted May 6, 2014 Share Posted May 6, 2014 Would it fit levin twinpots? Quote Link to post Share on other sites
5e colin Posted May 6, 2014 Share Posted May 6, 2014 no they nead to be cut down more to 260mm then !!!!!! Quote Link to post Share on other sites
russ78 Posted May 6, 2014 Author Share Posted May 6, 2014 as far as im aware there are two types of levin twin pots 260mm and 277mm make sure yours are 277mm and yes these will fit perfect Quote Link to post Share on other sites
russ78 Posted May 6, 2014 Author Share Posted May 6, 2014 (edited) if im right its the carrier on the levins that can be swapped for a celica carrier making them fit 277mm disks Edited May 6, 2014 by russ78 Quote Link to post Share on other sites
Turk Posted May 6, 2014 Share Posted May 6, 2014 Im confused anyone else know how to have a big disk with the levin twinpots. I read somewhere you can use levin 277mm discs with a 3mm spacer behind the disc. But i dont know what carrier to use. Quote Link to post Share on other sites
russ78 Posted May 7, 2014 Author Share Posted May 7, 2014 bump Quote Link to post Share on other sites
russ78 Posted May 11, 2014 Author Share Posted May 11, 2014 ttt Quote Link to post Share on other sites
morgey Posted May 11, 2014 Share Posted May 11, 2014 (edited) Im confused anyone else know how to have a big disk with the levin twinpots. I read somewhere you can use levin 277mm discs with a 3mm spacer behind the disc. But i dont know what carrier to use.To use the levin disc it needs the spacer and cutting down to 260mm Using the astra discs, it eliminates the need for the spacer under the disc but still needs cutting down to 260mm to fit levin twin pots. These are made to fit celica brake upgrades not the levin ones Edited May 11, 2014 by morgey Quote Link to post Share on other sites
morgey Posted May 11, 2014 Share Posted May 11, 2014 as far as im aware there are two types of levin twin pots 260mm and 277mm make sure yours are 277mm and yes these will fit perfectAll levins that had twinpots were 278mm but when bolted to the starlet they only fit under 260mm. With the celica carrier you might be able to use a bigger disc size Quote Link to post Share on other sites
5e colin Posted May 12, 2014 Share Posted May 12, 2014 ^^^^^ nice info morgey do the celica caliper brackets bolt to starlet hub ?????? Quote Link to post Share on other sites
russ78 Posted May 12, 2014 Author Share Posted May 12, 2014 (edited) as above this is good information but these disks are for celica brakes not levin brakes Edited May 12, 2014 by russ78 Quote Link to post Share on other sites
russ78 Posted May 13, 2014 Author Share Posted May 13, 2014 up Quote Link to post Share on other sites
russ78 Posted May 16, 2014 Author Share Posted May 16, 2014 bump Quote Link to post Share on other sites
Phil Posted May 16, 2014 Share Posted May 16, 2014 (edited) All levins that had twinpots were 278mm but when bolted to the starlet they only fit under 260mm. With the celica carrier you might be able to use a bigger disc size I cant see the celica carrier being any use on the levin setup. Celica have a hinged slider system, with one threaded into the carrier. The levin is a fully floating setup, two sliders. From what im seeing now as i go through these 'issues' myself lol (based on a 95 ish levin setup VS a Celica ST165 GT4 setup) ^^^^^ nice info morgey do the celica caliper brackets bolt to starlet hub ?????? Yes Colin they do. Phil Edited May 16, 2014 by Philm Quote Link to post Share on other sites
russ78 Posted May 20, 2014 Author Share Posted May 20, 2014 ttt Quote Link to post Share on other sites
russ78 Posted May 30, 2014 Author Share Posted May 30, 2014 bump Quote Link to post Share on other sites
russ78 Posted June 1, 2014 Author Share Posted June 1, 2014 up Quote Link to post Share on other sites
russ78 Posted June 2, 2014 Author Share Posted June 2, 2014 up Quote Link to post Share on other sites
russ78 Posted June 7, 2014 Author Share Posted June 7, 2014 bump Quote Link to post Share on other sites
russ78 Posted June 13, 2014 Author Share Posted June 13, 2014 up Quote Link to post Share on other sites
russ78 Posted June 22, 2014 Author Share Posted June 22, 2014 bump Quote Link to post Share on other sites
russ78 Posted June 27, 2014 Author Share Posted June 27, 2014 up Quote Link to post Share on other sites
russ78 Posted July 23, 2014 Author Share Posted July 23, 2014 up Quote Link to post Share on other sites
