They are all different.. Td04 then you have different letters relating to differences in exhaust housing and then numbers that relate to compressor wheel and then a final letter to do with compressor housing.
I might have that all wrong but that's the general idea. Basically you could be fitting a smaller turbo with a bigger exhaust side that's going to cause more lag with less power, the opposite or any of the above combinations..
Edited by richardc9052
Aslong as it has the same manifold and downpipe flanges, and the correct bores for the oil drain and feed and the water lines you'll be able to fit it no bother. However it might be a slightly different variation.
