koolza132 Posted May 6, 2014 Posted May 6, 2014 I have got a TD04 with no play from some one who's had it sitting around my td04l has play is a td04 ok to put on, whats the difference? Quote
Banbury Glanza Posted May 6, 2014 Posted May 6, 2014 Pretty a sure they are exactly the same mate, I might be wrong, but it won't do any damage putting the td04 on there Quote
richardc9052 Posted May 7, 2014 Posted May 7, 2014 (edited) They are all different.. Td04 then you have different letters relating to differences in exhaust housing and then numbers that relate to compressor wheel and then a final letter to do with compressor housing. I might have that all wrong but that's the general idea. Basically you could be fitting a smaller turbo with a bigger exhaust side that's going to cause more lag with less power, the opposite or any of the above combinations.. Edited May 7, 2014 by richardc9052 Quote
gorganl2000 Posted May 7, 2014 Posted May 7, 2014 http://www.ukstarletowners.com/topic/80675-best-td04-donor-car/ some info there Quote
Liam_D Posted May 7, 2014 Posted May 7, 2014 Aslong as it has the same manifold and downpipe flanges, and the correct bores for the oil drain and feed and the water lines you'll be able to fit it no bother. However it might be a slightly different variation. Quote
seab Posted May 11, 2014 Posted May 11, 2014 Td04l is low flow. Same turbine side just smaller compressor side Quote
