akaye4000 Posted May 22, 2014 Posted May 22, 2014 Anyone know where I can get ds2500/3000 pads from? Quote
Keri-WMS Posted May 22, 2014 Posted May 22, 2014 Us, if Ferodo make them! Drop me a PM with the exact year / engine etc etc? Quote
RobSR Posted May 22, 2014 Posted May 22, 2014 Are you running a ST202 front brake package? If so what exactly did you use? Seen so many different things said.. Quote
akaye4000 Posted May 22, 2014 Author Posted May 22, 2014 (edited) St202 calipers and carriers bolt straight on and astra discs turned down to 277mm:) job done Edited May 22, 2014 by akaye4000 Quote
daniel_g Posted May 22, 2014 Posted May 22, 2014 St202 calipers and carriers bolt straight on and astra discs turned down to 277mm:) job doneAre they single pistons ? Quote
daniel_g Posted May 22, 2014 Posted May 22, 2014 Also it that the 1.8 or the 2LOr does it not matter ? Quote
Amjad Posted May 22, 2014 Posted May 22, 2014 Just need to know piston number and disc size to know which set is which. Got mine of ST185 (late spec) 277mm discs, single piston Quote
akaye4000 Posted May 22, 2014 Author Posted May 22, 2014 Single piston from a 1995 2.0 gt import Quote
akaye4000 Posted May 23, 2014 Author Posted May 23, 2014 Us, if Ferodo make them! Drop me a PM with the exact year / engine etc etc?Pm'd Quote
RobSR Posted May 25, 2014 Posted May 25, 2014 Thanks for the info! any spacers required behind the disc? Quote
Amjad Posted May 25, 2014 Posted May 25, 2014 You need to take 1.5mm off the back of the disc where it faces the hub INC, then get a spigot ring made up to match the hub Quote
akaye4000 Posted May 26, 2014 Author Posted May 26, 2014 You need to take 1.5mm off the back of the disc where it faces the hub INC, then get a spigot ring made up to match the hubThis wasn't the case as did take 1.5mm off and put the disc in the wrong place and was alot better fit leaving it alone which I have done now with a new pair of discs, can get a spigot ring tho Quote
Amjad Posted May 26, 2014 Posted May 26, 2014 Dunno, mine were okay when I had the discs modified Quote
Keri-WMS Posted May 27, 2014 Posted May 27, 2014 Ferodo don't make these pads any more in DS2500! Quote
