fiddlersport Posted May 23, 2014 Posted May 23, 2014 (edited) Any one have the pin outs for the 4efe ecu uk 98 2 plug ? thank you Edited May 23, 2014 by fiddlersport Quote
fiddlersport Posted May 27, 2014 Author Posted May 27, 2014 I checked my ecu, the numbers are different from the picture above the numbers on my ecu is :89661-10180211000-6570 Quote
teta Posted June 8, 2014 Posted June 8, 2014 hi there just open your ecu you will find the pin outs inside the ecu Quote
richardc9052 Posted June 9, 2014 Posted June 9, 2014 hi there just open your ecu you will find the pin outs inside the ecuNot always the case.. I haven't ever found the pin out on the inside of any of my ecu Quote
karl. Posted June 9, 2014 Posted June 9, 2014 Not always the case.. I haven't ever found the pin out on the inside of any of my ecu Im nearly sure its on all of them, If you open it when the pins from the plug connect to the ecu it should be written on the board Quote
richardc9052 Posted June 9, 2014 Posted June 9, 2014 <a href="http://s947.photobucket.com/user/richardc905/media/517F2283-561E-4325-87A0-2937E684BDE1_zpsyactuyp8.jpg.html" target="_blank"><img src="http://i947.photobucket.com/albums/ad316/richardc905/517F2283-561E-4325-87A0-2937E684BDE1_zpsyactuyp8.jpg" border="0" alt=" photo 517F2283-561E-4325-87A0-2937E684BDE1_zpsyactuyp8.jpg"/></a> Quote
karl. Posted June 9, 2014 Posted June 9, 2014 If you look at the last picture you can see where the pins connect to the board the writing, Thats the pinout there. And if a EP82 has two board in the ecu does that mean its a PNP? Quote
richardc9052 Posted June 9, 2014 Posted June 9, 2014 Thanks I couldnt ever find what people where talking about hahaha Now you have pointed it out i dont know why i couldnt see it before :/ Quote
klyfax Posted June 9, 2014 Posted June 9, 2014 All Toyota ECU from '80, '90 and early '00 have pinouts on the board. Quote
Stu Posted June 9, 2014 Posted June 9, 2014 Nearly all - there are exceptions like 7mgte and a few others Quote
fiddlersport Posted June 10, 2014 Author Posted June 10, 2014 I popped the lid on the 5e ecu i will be using on the conversion, the writing is small, camera could not capture it. Quote
