I'll get some pics up at the weekend as she is filthy from picking her up in the rain :(
Thanks for the warm welcome all!
This car Honestley is the most fun i have ever had in a car!
Quick q actually does anyone else have a fan operated on a manual switch? If so , do u use a temp
Sender to get it on /off at certain temps?
Or like me just keep it on all time whilst driving
Cheers
there is no manual switch for the rad fan it must have been fitted by the previous owner,
If you have an after market temp gauge then I would switch it on for 30-40 seconds to bring down the temp once it has reached the temp rating on your thermostat.
To identify the temp rating on the stat you will need to take it out and the temp rating will be stamped on it if i remember correctly it should be 82-87 degrees.
Edited by H_D
Thanks H D for the info , i'm using standard temp gauge she is cooling well at the mo tho so may leave it as it is.
Thanks liam d for the welcome 👍
Hey nessa and jim thanks for the welcome!
I will on the comp tommorow when i can get her first clean in. Dam weather!
