Adam M Posted May 29, 2014 Posted May 29, 2014 Short and simple i guessWhat is a safe boost level for a glanza with a td04 Have forged rods/pistons/acl race bearings/3mm gasket/front mount etc etc lots of work doneWalbro 255 pump , (think i'm in stock injectors not sure how to tell)It's running 12 psi at the mo If i fit a boost controller can i turn it up or is a tuner needed ?Thanks adam Quote
Adam M Posted May 29, 2014 Author Posted May 29, 2014 Ok , thanks for the reply this is my first turbo car so still getting clued up on things.Could anyone recommend a good tuner? I'm in leicestershire so the closer the betterThanksAdam Quote
ankers Posted May 29, 2014 Posted May 29, 2014 Hiya mate im going td04 soon and from my mouths of research people usually run 1.4bar max on a td04 Quote
russ78 Posted May 29, 2014 Posted May 29, 2014 (edited) your limits wont be on the engine as it is forged, your limit will be on the TD04 as it wont take much more than 1.3/1.4 bar of boost but its already been said get some decent management should be your first port of call buddy Edited May 29, 2014 by russ78 Quote
Adam M Posted May 29, 2014 Author Posted May 29, 2014 Thanks for the replies all , did have a good look through but Couldn't find the info. I will get a good ecu russ and take her to the dyno see what they think it's capable of Thanks allot all! Quote
Jim* Posted May 30, 2014 Posted May 30, 2014 (edited) As said don't just turn the boost up without getting a tuner to map it or she will go bang regardless weather she is forged or not buddy!Edit** give mike at tuning developments a call he will be able to advise you on what will be suitable for what you want mate! Edited May 30, 2014 by Jim* Quote
H_D Posted May 30, 2014 Posted May 30, 2014 (edited) if you are based in Leicester contact future-Motorsports,My Glanza is there at the moment and so is Jamie1st.Ask for bijal and tell him I sent you. http://www.futuremotorsports.com/ Edited May 30, 2014 by H_D Quote
gorganl2000 Posted May 30, 2014 Posted May 30, 2014 get it tuned for sure as the others have said as for max boost, the usual on a td04L is around 1.4bar....but sometimes guys hit 1.6 bar for a short time (this tends to shorten the turbo's life)it will most likely taper off in the high revs anyways to around 1.1 - 1.2 bar if you use a stock tdo4L Quote
richardc9052 Posted May 30, 2014 Posted May 30, 2014 Is it a td04l though? I know on some of the bigger versions the Subaru lads have ran up to 2 bar Quote
Adam M Posted May 30, 2014 Author Posted May 30, 2014 Thanks all ! , @jim i sent them an e-mail as they seem to have a really good reputation!And also thanks H D i'll give them a call!I will definatley get her looked at before contemplating increase of power as she has abit of an unknown history.. ( have paperworkFor 9k labour without price of parts fitting all these insane mods) @richard it sais on the paperwork she is just a td04 mate Thanks allot all! Great info.I'll let you all know how she gets on in about 3-4 weeks time Quote
richardc9052 Posted May 30, 2014 Posted May 30, 2014 Yeah i saw the glanza you bought for sale on facebook. The guy was trying to say the engine had Walbro internals Quote
Adam M Posted May 30, 2014 Author Posted May 30, 2014 Yeah i think i hit abit of a barn find richard as the car itself isnt the best of nick, but the engine runs great and have a massive list of receipts.Did a straight swap with my ep2 civic which i thought was incredible for a rare glanza with this kind of work. Just needs allot of tlc! Quote
Adam M Posted May 30, 2014 Author Posted May 30, 2014 (edited) But then there is nothing to say its had an engine swap, parts removed, been ragged to bits.. so abit of hit and miss i guess, i'll fix her up tho 👍 Edited May 30, 2014 by Adam M Quote
Jim* Posted May 30, 2014 Posted May 30, 2014 Yeah I've had all my work done by tuning developments and haven't got a bad word to say about them mate! Quote
