Ben-EP95 Posted June 2, 2014 Posted June 2, 2014 Hello all! I am going though the turbo conversion alright so far but when trying to connect up the gear box off my EP95 the turbo engine the back plate/dust plate seems to be getting in the way?? I noticed the n/a engine has a detachable plate, can i just cut mine to fit? Or do i have to change it over which would be a pain haha? Thanks Ben Quote
daniel_g Posted June 2, 2014 Posted June 2, 2014 Hi buddy, you might need to remove and swap over the sandwich plates behind the flywheel. The 4wd one is in 2 parts like you said, it has to clear the transfer box iirc. It all has to be covered up so the flywheel isnt exposed to stones an shit. You should fire a few pics up of your EP95 Quote
Ben-EP95 Posted June 14, 2014 Author Posted June 14, 2014 Thanks for the reply.In the end i matched up the n/a one and cut mine to fit . Also found the rear gearbox mount different? The original is offset so need to shim mine out and for some reason my engine is sitting at a angle in the car. Although Both engine and gear box mount measure the same hmmmm. I will get pictures up just waiting to get it on the road then do a write up (Y). Quote
bucketep91 Posted June 15, 2014 Posted June 15, 2014 What do u mean its sitting at an angle in the car? Have you swapped the sumps over? U need to use the 4efe's sump on your fte. Quote
Browner Posted June 15, 2014 Posted June 15, 2014 I had the same problem with my RWD ep85 the engine sat at a slight angle when I put the new one in Quote
shorty Posted June 16, 2014 Posted June 16, 2014 Why are you changing the rear gearbox mount? Why do you not just leave the 4wd one in there. The only thing you need to swap is the engine. The mounts will all be fine and the engine mount will just line up wether its the 4wd or 4efte one. And as charlie said have you swapped the sump and put an oil flreturn on the 4wd sump as you need to do that for it to all fot and work. Quote
daniel_g Posted June 16, 2014 Posted June 16, 2014 Yeah you use both 4paw box mounts.You dont even need to swap the engine, just bolt a turbo onto it Quote
shorty Posted June 16, 2014 Posted June 16, 2014 Exactly! Well the ep85 ya can as its a gen 1 jdm so is basically an na gt engine. But the ep95 will be a chocolate na engine so probs just melt lol. Quote
Calum122 Posted June 26, 2014 Posted June 26, 2014 Haha Shorty you Display picture makes me roar! Quote
Calum122 Posted July 1, 2014 Posted July 1, 2014 Reminds me of Jack Nicholson in The Departed lmao! Quote
shorty Posted July 1, 2014 Posted July 1, 2014 (edited) It is indeed mr jack nicholson just cant remember what from, might be bucket list tbh. Edited July 1, 2014 by shorty Quote
Ben-EP95 Posted July 7, 2014 Author Posted July 7, 2014 Sorry haven't been on here for a while! Urrrm well i have used the original mounts just changed the inserts for poly bushed ones. I know the rear gear box mount was offset so i can see why that needs spacing (not a issue). But the engine and gearbox tilt downwards towards the passenger side. Although i can't see why really. I can adjust them no problem was just trying to work out why. Yeah I switched the sumps otherwise i wouldn't have got this far lol. No i have a stage 2 TD engine so worth the swap (Y). Thanks for the replies . Quote
bucketep91 Posted July 7, 2014 Posted July 7, 2014 How much of a tilt is there? Got any pics?Now that youve said it, mines looks like it sits at an angle in this pic. Will have to check it out Quote
Scoobysvx Posted July 7, 2014 Posted July 7, 2014 Some pics would help me out too as I'm now in the process of converting mine Quote
Ben-EP95 Posted July 7, 2014 Author Posted July 7, 2014 I do have pics but none that show the tilt i will get some by the weekend when i go down the unit. It looks similar if not slightly more to bucketep91's. Quote
Ben-EP95 Posted July 7, 2014 Author Posted July 7, 2014 Hard to tell if yours is actually on a tilt or just the picture. Let me know mate. Hope not! Quote
Ben-EP95 Posted August 8, 2014 Author Posted August 8, 2014 Hello all again, just wondering with the loom off the engine. The glanza had two holes on the bulk head where the 95 only has one? Did you guys drill one in place or routed the wires via a different location? Thanks Ben Quote
bucketep91 Posted August 8, 2014 Posted August 8, 2014 I took all mine through the one hole. 1or 2 wires did need extending tho but was a piece of piss. Quote
Ben-EP95 Posted August 8, 2014 Author Posted August 8, 2014 Great, thanks i have done the same too now . Quote
