Hi guys, ive just purchased a tial external wastegate as well as tf035 and mani etc.
I do not have a ebc and was wondering to run 1 bar do i simply purchase a 1 bar spring and install it? Bit new to the idea of an external wastegate
Dan
Edited by Haresign
Yeah thats exactly what you do.
The top port of the EWG is left open to atmosphere if you arent running an EBC, and the bottom port goes directly to the nipple on the compressor housing on the turbo.
  • 5 months later...
The newer vband style Tial ones are water cooled.... Hence the extra ports...
You want to put a spring in for the lowest amount of boost you want to run...
You use a boost controller to raise it from there... You cant reduce boost lower then the spring pressure!
I was wondering this. I'm guessing you don't need to run the water cooled lines. Would that be more suited for race setup?
See I'm setting mine up to run spring pressure at the min it's only so I can drive the car round to the guy that is mapping my car as he's going to map the car a fit my avcr
