jamesherring93 Posted June 9, 2014 Posted June 9, 2014 I have no spark I've changed igniter,ignition coil, spark plugs,distubtor, cap.and rotor arm.. Need help Quote
5e colin Posted June 9, 2014 Posted June 9, 2014 brake in the wire from ecu to dizzy or coil or knakered ecu and as mentioned above the coil neads to be earthed Quote
Chops Posted June 9, 2014 Posted June 9, 2014 i just sorted this problem, youll have to follow the lead all over the place and try and isolate a faulty wire with a multimeter bud. grounds are also something to pay extra attention to. Quote
jamesherring93 Posted June 9, 2014 Author Posted June 9, 2014 Yeh both igniter and ignition coil are grounded and haven't found no wires cut yet fort maybe ht leads or king lead Quote
Chops Posted June 9, 2014 Posted June 9, 2014 (edited) king leads are always going wrong, if you have some scrap wire you can make a temp one to see if it is the king lead. they can be intermittent though, appearing to work when you test it but not when its on the car. Edited June 9, 2014 by Chops Quote
jamesherring93 Posted June 9, 2014 Author Posted June 9, 2014 Ok il buy a new one for the sake of £20.. But what wires was you on about chasing? Quote
Chops Posted June 9, 2014 Posted June 9, 2014 (edited) the wires that connect the ignition system together, particularly ones that come close to heat sources or are in areas that make them likely to be susceptible to corrosion. its probably something small, though mine turned out to be my king lead, a knackered connection and my alternator. Edited June 9, 2014 by Chops Quote
jamesherring93 Posted June 10, 2014 Author Posted June 10, 2014 See I keep saying this and the garage say na defo the igniter that fault but I don't wanna pay £270 for new one :/ Quote
Chops Posted June 10, 2014 Posted June 10, 2014 phh bawls to that, i got quoted 260 odd for a new alternator, no way that was happening. get yourself a second hand jobbie, they might even be the same as the uk spec 4efe igniters, though dont quote me on that, im no professional leccy Quote
jamesherring93 Posted June 10, 2014 Author Posted June 10, 2014 Na iddy sorted me a second hand one off the glanza his breaking but garage reckon that faulty think there taking me for a mug Quote
5e colin Posted June 10, 2014 Posted June 10, 2014 did u check for breaks in the wiring with a multimeter ??? no point in buying parts if it aint broken Quote
jamesherring93 Posted June 11, 2014 Author Posted June 11, 2014 They said there no obvious signs of breaks in the wiring..I even got another ecu in case mine was faulty but still nothing Quote
5e colin Posted June 11, 2014 Posted June 11, 2014 ha ha really they said obvious !!!!! dont think they checked for continuity attal !!!! they just looked at the wires as a visual by the sound of it you changed everything now except the wiring !!!! issue is most likely there ! Quote
jamesherring93 Posted June 11, 2014 Author Posted June 11, 2014 Yeh what they said and reckons it cost to much to check the wiring has any one got an Idea on what part of wiring I should look at? Quote
5e colin Posted June 11, 2014 Posted June 11, 2014 o man really takes 10/15 min to check you can do this urselve first get your ecu pinout diagram then disconnect the ecu now you can access the pins on the plug al you knead is a length of wire to reach from your multimeter inside to the engine bay plugs on dizzy coil and igniter Quote
jamesherring93 Posted June 11, 2014 Author Posted June 11, 2014 Where can I get the diagram for pin outs? Quote
5e colin Posted June 11, 2014 Posted June 11, 2014 here you go http://www.toyotagtturbo.com/forums/showthread.php?20491-EP82-EP91-ECU-Pinout-Diagram check pin 3,4,5 ,17 and 18 check pin 22 to to be safe Quote
jamesherring93 Posted June 11, 2014 Author Posted June 11, 2014 Ok thanks and all on the first plug yeh? Quote
5e colin Posted June 12, 2014 Posted June 12, 2014 o yes i forgotten to say that , indeed the main big plug the 26 pin 1 Quote
jamesherring93 Posted June 18, 2014 Author Posted June 18, 2014 Garage reckon they need a scope to check it..but could this be related to crankshaft position sensor..?? Quote
5e colin Posted June 18, 2014 Posted June 18, 2014 we dont have crank position sensor mate its in the dizzy cam sensors everything is controled by our dizzy Quote
jamesherring93 Posted June 18, 2014 Author Posted June 18, 2014 I dunno what to do man might get it home and check it all myself as garage don't seem helpful Quote
