As do skylines.
It's doable. Blitz to a turbo kit for the 20v's with a chamber for the Itb's otherwise you'd need a custom one.
You'd also need an adaptor plate to go from the bodies to the 4e head obviously.
Edited by morgey
Would be more throttle response as boost can build up much closer to the combustion chamber filling the plenum off throttle rather than having it under direct vacuum.
Tbh I doubt there'd be huge gains on a turbo'd car. But if you've got the no how and the equipment then go for it.
Getting a good map signal could also be a problem, You would want a vacuum chamber and a pulse dampener. I would have thought
  • 1 year later...
