dan106 Posted June 29, 2014 Posted June 29, 2014 The oil light started staying on for a while, thought it was because I've been parking half on a kerb recently, but it's started coming on for a while then turning off and flickering on idle. Oil was a bit low when it first came on but now it's at the max it still doing it every now again.What else could it be indicating? Slightly worried the oil pick up is blocked as I've twatted the sump a few times recently.But I don't really have time to pull the sump off atm, wanted to see if it could just be a sensor or something beforehand Quote
Jamie5414 Posted June 29, 2014 Posted June 29, 2014 (edited) Does seem oil pickup is getting blocked, might be worth swapping it out or cleaning (at same time clean out sump and install magnetic sump plug) or if you use engine flush give that a go, a few people on here don't advise using it though, it could just make the problem worse by dragging all the shit around your engine. Edited June 29, 2014 by Jamie5414 Quote
dan106 Posted June 29, 2014 Author Posted June 29, 2014 It's not blocked with crap I don't think, used engine flush before and it was fine, I think the sumps bent up so much it's hitting the pick up, but I've never the sump off so I'm not sure how close it all is, and I've got new oil and filter and magnetic sump plug to go in, but was gonna do it all at the same time as the cambelt Quote
daniel_g Posted June 29, 2014 Posted June 29, 2014 Could try a new oil pressure switch, it sits on the front of the block near the slave cylinder. Quote
