Jamie5414 Posted July 6, 2014 Posted July 6, 2014 Is a Manifold/exhaust system that is LEAKING exhaust gas a failure? any MOT testers (daniel g?) that could reply that would be great Quote
daniel_g Posted July 6, 2014 Posted July 6, 2014 Im not an MOT tester just yet haha, nearly, done a lot of training just need to do the course Ehh as far as im aware its an advisory if its not excessively loud. It might fail if its leaking so bad that it affects the emmisions. Other than that it should be ok, ie a small blow. Quote
5e colin Posted July 7, 2014 Posted July 7, 2014 its a fail the lambda reading will be to high !!!!!! Quote
Jhandy Posted July 8, 2014 Posted July 8, 2014 (mot tester) depends how bad the leak is, but as above, it can effect the emissions. jake Quote
Barnz74 Posted July 25, 2014 Posted July 25, 2014 its a fail the lambda reading will be to high !!!!!! Exactly what mine failed on last week. Yet to check it to see if it has any leaks. Grrrr Quote
5e colin Posted July 26, 2014 Posted July 26, 2014 Exactly what mine failed on last week. Yet to check it to see if it has any leaks. Grrrr 99% sure you have a leak somewhere between turbo and back box i learned the hard way my reading was off to so i thought my 02 sensor was fucked so went toyota to buy new 1 , went back to test centre and same result came out !! then the tester told me its almost always a leak in exhaust !!! Quote
shaungt Posted August 9, 2014 Posted August 9, 2014 It depends on if it's excessive but I did mot a Volvo the other week with a cracked manifold blowing badly amd it passed the emissions ok Quote
