driveshaft bit that goes into gearbox plus other bits***
glanza thermostat housing with all sensors
water pipe from thermostat housing to water pump pipe behind block
rrfpr
both fuel line breather pipes
Top cam cover with bolts
Panel under the windscreen
Edited by fremyjay
Ahhh right... well lambda there if you need it....
Sorry to spam but u dont have std rad kicking about do you?
Ok cheers dude and afraid not
76770348-170E-41DE-BC21-C5694D470A0B_zps
pm'd
I got the manifold gasket and lamda sensor with plug pm me s offer
Pm me a price bud and will let you know
Im currently bidding on a sard one but if you pm me a price and i will let you know if it falls through bud
I've for a 98spec thermo housing minus the thermostat and big box of pipes am sure there will be a few is the one to water pipe.
I have a set here but im missing the end that goes in the gearbox off one and need two outer boots, so trying to find which is cheaper, wether buying cv boots ect or buying a decent set of shafts, all the other parts i may have already but will let you know corofin, but if anyone can also help with a selection of nuts, jubilee clips and odd vacuum pipes ect from engine bay would be great :thumbsup::thumbsup::thumbsup:
Edited by fremyjay
Bud PM me i have all standard hoses/blue vacuum piping. Great Condition Driveshafts ( got to be cheaper than buy all boots ect...) let me know
should have all that here too, have a full car for breaking, also have inner CV cups.... its pretty much stripped to the ground now.. shed full of OEM parts
