best place to buy fuel connectors an6 also what connector do i need for rfpr to the line
  On 7/25/2014 at 9:25 AM, jellybaby said:
colin u my friend are a star :)
will I need aprrox 6 of the second item listed ?????
as I will be running a return braided line etc
http://www.ebay.co.u...=item54039b4811 x2 for the flow and return on the fpr
http://www.ebay.co.u...=item54062573fb x3 for the return of the fuel rail, flow of the fpr and returb of the fpr.
If you plan on running your guage in another place you will need another 2 of each.
http://www.ebay.co.u...=item58ab4f0283 also get 2m of pipe to just to be sure so as your not left short some day.
Edited by karl.
im doing the same for my zisco rail. i added up the price of speedflow fittings and for braided fuel hose and 10an breather hose plus all the fittings i would need its over £250 for the lot!
All my fuel system is -6
Well apart from the feed from the in tank pump to my swirl pot and return to the tank from my FPR.
I went to my local hose shop and had all of my lines and fittings pressed on for about £100. Much cheaper than aeromotive type stuff and does just as good of a job.
I went for aeromotive fittings on my oil cooler and regret it. A massive faff about, make sure you at least use Torques. The other cheaper stuff on eBay is really bad!
