jellybaby Posted July 25, 2014 Share Posted July 25, 2014 i need to get braided lines etc for my zisco fuel rail etc I got the an10 to an6 converter. but I need one that threads Into the fpr but then goes an 6 etc hope that makes sence Quote Link to post Share on other sites
Chris Green Posted July 25, 2014 Share Posted July 25, 2014 Torques on eBay. Most FPR's are an6, so you'll be looking to use a male to male adaptor. Quote Link to post Share on other sites
jellybaby Posted July 25, 2014 Author Share Posted July 25, 2014 Cheers Quote Link to post Share on other sites
5e colin Posted July 25, 2014 Share Posted July 25, 2014 the thread on most rrfpr is 1/8" NPT you will need 3x of these http://www.ebay.co.uk/itm/AN-6-AN6-AN-06-to-1-8-NPT-Straight-Adapter-/360837761041?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item54039b4811 you will need some off these http://www.ebay.co.uk/itm/AN-6-AN6-AN-06-STRAIGHT-Swivel-Seal-Hose-Fitting-/360880370683?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item54062573fb and a bit of this http://www.ebay.co.uk/itm/AN-6-8mm-5-16-Stainless-Steel-Braided-Fuel-Hose-1-m-/380831203971?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58ab4f0283 Quote Link to post Share on other sites
jellybaby Posted July 25, 2014 Author Share Posted July 25, 2014 (edited) colin u my friend are a star will I need aprrox 6 of the second item listed ????? as I will be running a return braided line etc Edited July 25, 2014 by jellybaby Quote Link to post Share on other sites
5e colin Posted July 25, 2014 Share Posted July 25, 2014 jelly baby you can also buy this its the hose and 2 fittings already on each other just npt needed http://www.ebay.co.uk/itm/8mm-AN-6-5-16-Stainless-Braided-Hose-With-AN-Fittings-125cm-For-Oil-Fuel-Hose-/330999908062?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d1121c6de Quote Link to post Share on other sites
jellybaby Posted July 25, 2014 Author Share Posted July 25, 2014 so basicly them pipes with the x3 in the 1st link ??? Quote Link to post Share on other sites
karl. Posted July 25, 2014 Share Posted July 25, 2014 (edited) colin u my friend are a star will I need aprrox 6 of the second item listed ????? as I will be running a return braided line etc http://www.ebay.co.u...=item54039b4811 x2 for the flow and return on the fpr http://www.ebay.co.u...=item54062573fb x3 for the return of the fuel rail, flow of the fpr and returb of the fpr. If you plan on running your guage in another place you will need another 2 of each. http://www.ebay.co.u...=item58ab4f0283 also get 2m of pipe to just to be sure so as your not left short some day. Edited July 25, 2014 by karl. Quote Link to post Share on other sites
jellybaby Posted July 25, 2014 Author Share Posted July 25, 2014 my pressure reg has a gauge already on it Quote Link to post Share on other sites
garrygt Posted July 25, 2014 Share Posted July 25, 2014 im doing the same for my zisco rail. i added up the price of speedflow fittings and for braided fuel hose and 10an breather hose plus all the fittings i would need its over £250 for the lot! Quote Link to post Share on other sites
karl. Posted July 25, 2014 Share Posted July 25, 2014 my pressure reg has a gauge already on it I mean if you want to put the guage somewhere else Quote Link to post Share on other sites
TimD Posted July 25, 2014 Share Posted July 25, 2014 All my fuel system is -6Well apart from the feed from the in tank pump to my swirl pot and return to the tank from my FPR. I went to my local hose shop and had all of my lines and fittings pressed on for about £100. Much cheaper than aeromotive type stuff and does just as good of a job. I went for aeromotive fittings on my oil cooler and regret it. A massive faff about, make sure you at least use Torques. The other cheaper stuff on eBay is really bad! Quote Link to post Share on other sites
jellybaby Posted July 25, 2014 Author Share Posted July 25, 2014 yer dw I will use torques by one by right etc I don't mind how much it is at end of day I like the look of them and also just makes things easyer for me when I want to change stuff. Quote Link to post Share on other sites
