Fitted a twin adaptor for the oil pressure port so I could run an after market gauge.they are made of alloy and are very very soft.
I did it up to the point it was resonably tight being careful not to go mad and..........
Fecking great.so now I am so screwed. I have a hole in my block that oils goin to jet out of and I cant block it. Last hope was an easy-out............
I was so lucky with this, and I didnt even have to take the turbo off. Before I looked up the easy-outs I read horror storys on Google were people had snapped the easyouts In the already snapped of oil pressure thread so needless to say I was so worried but alls well now thank god.
I wouldnt use an alloy adaptor again.please be warned.
Ddd
I opted for a remote T piece, it's on the end of a bit of braided line. So far so good.
The nice thing about alloy is that it's softer than the block. So you damage the fitting rather than the block!
Yeah I would opt for a remote piece if I do decide to go again.they have there own flex to them and that helps a little I guess.
and yeah thats true, that and the easy-out really bit down on the alloy piece stuck in there and came out nicely.was still tight little bugga.
Happened same to
Me, well it started leaking after like a week, so checked it and it snapped, lucky I did really!
Fitted a remote t and didn't have any issues after
The thread is tapered so no copper washer is needed. Also no serious tightening is needed. Just put some Teflon tape on the threads and snug it up. Even aluminum should have hold...
