So I brought a jam racing ecu off a member I put it in let it run ect took it for a hard drive but no real difference surely this cant be normal? ??
Is it definetly genuine, are the seals on the die of the ecu untouched? i noticed quite a bit of difference when i put mine in, if the seals are torn then some may have messed with it.
I never had a fault with it in my car mate , work 100% instant power gains , all seals intact and never messed with , got people on here that will vouch for it working spot on mate , no ones messed with the wiring or anything on your car have they mate ? , keep me posted please :) Toby
These ecu's work better off stock pressure regulators if your running an aftermarket fpr try putting stock one back on since it was T-dogs old ecu I believe it's a genuine :)
run the engine hot and rev it to the limiter 1s in neatral if it revs past 7.2 then it will be ok and settle soon if it hits the 7.2oorpm limiter then your fucked and sold a stock ecu with a very expensive sticker on it
What mods have you got on it mate , deffo revs past 7200rpm ( I never had the balls to go past 8000rpm lol ) and was running 1.2 bar with it and fuelled perfect :)
Just relocated air filter and decat and fpr thats it mate it probably just needs time to settle in mate I might remove battery and ecu leave it for a while and connect it up again see what happens
