Ollieh17 Posted July 31, 2014 Posted July 31, 2014 (edited) Fitted my new td04 and it wont boost above 0.1bar. Beyond that is makes a high pitch squeeling noise. I have tested for boost leaks by covering the turbo intake, this lead to one of the intercooler pipes sucking in on itsself. Looked at this pipe and couldnt see any rips etc?!? Is the leak likely to be before or after this silicone?!?Pissing me off now, old turbo was smokey so swapped it. Now no boost. Just want rid of the car Edited August 1, 2014 by Ollieh17 Quote
Dean_mc88 Posted July 31, 2014 Posted July 31, 2014 surely if its collapsing in on itself it has no leaks, does the car cut out when this happens? if not maybe blockage somewhere, if it does cut out then no boost leaks. Quote
Ollieh17 Posted August 1, 2014 Author Posted August 1, 2014 https://www.facebook.com/photo.php?v=10152578344331147&set=o.50382194069&type=2&theater Video of the noise im getting, no oil in the intercooler or any smoke Quote
Zeldoz Posted August 1, 2014 Posted August 1, 2014 you sure you got stuff plumbed in correctly?... Quote
Ollieh17 Posted August 1, 2014 Author Posted August 1, 2014 Yuppp only took the hotside off the car and put back on the same as before. Sounds like a massive boost leak that would be pretty noticeable Quote
daniel_g Posted August 1, 2014 Posted August 1, 2014 Did you touch the wastegate at all ?Other than that the turbo may be fucked. Quote
Ollieh17 Posted August 1, 2014 Author Posted August 1, 2014 Nope wastegate is welded and as it was im sure. If its the wastegate it would make a distincitve noise right, like gas leaking through screamer etc? Quote
daniel_g Posted August 1, 2014 Posted August 1, 2014 Aye it would make a leaky hissing noise.Is the EWG boost ring sitting right ? Quote
Ollieh17 Posted August 1, 2014 Author Posted August 1, 2014 The ring did fall out when fitting but put it back in. May take it off and have a look again. Just praying it isn't the turbo...again Quote
daniel_g Posted August 1, 2014 Posted August 1, 2014 Just check the ring sits totally flush and seals properly.Could be an easy fix for ya Quote
keirz Posted August 3, 2014 Posted August 3, 2014 A turbo so fucked it can only produce that little boost would dump all your oil in a few seconds.If you rotated the turbo then make sure that the rubber seal around the center housing is still intaked and that it is all seated back properly.Are you running a vac direct from comp nipple to side port to try wastegate spring pressure? Or is it on boost controller?It will be a leak its just a case of finding it, check manifold to turbo also. Quote
Ollieh17 Posted August 3, 2014 Author Posted August 3, 2014 Turbo was fucked mate. A little bit of oil in the pipings Quote
keirz Posted August 3, 2014 Posted August 3, 2014 But that would not cause that low a boost level Quote
Ollieh17 Posted August 3, 2014 Author Posted August 3, 2014 New turbo on and its fine now. Had a similar issue with a ct9 and all worked fine after swapping the turbo Quote
