Mernagh Posted August 7, 2014 Posted August 7, 2014 I recently changed the engine in my glanza S (4efe) I changed it to another 96 spec glanza S engine and ever since my car idles at 2000 rpm and won't drop and sometimes it drops to 1200 rpm and goes up to 2500rpm as if it has lifted cams!.. I cleaned iacv and changed the gasket so can't be that might just be f**ked Any idea what this could be Quote
rinseep82 Posted August 7, 2014 Posted August 7, 2014 It sounds like it's hunting check all vac pipes and all un used inlet pipes are blocked off listen around the engine for any hissing noises Quote
rinseep82 Posted August 7, 2014 Posted August 7, 2014 If all fails try adjusting the idle screw turn it down and see how you get on with it Quote
littlegreenmonster Posted August 30, 2014 Posted August 30, 2014 Where is the idle screw matey ?? Quote
spoon Posted November 25, 2014 Posted November 25, 2014 i'm having the same issue with my glanza s, when the engines running if i try block off the throttle body the engine should stall but it doesn't. its like theres an air leak of some sort around the inlet but it was fine before i parked it up. it was stood for 6 months then i started it up and now i have this issue but when the car warms up the revs calm down and then it starts hunting. Quote
Stu Posted November 26, 2014 Posted November 26, 2014 What happens if you unplug the tps? Revs stay the same or change? Quote
fiddlersport Posted November 27, 2014 Posted November 27, 2014 changed my standard to a rolla mani and it did the same, the tps was different so i changed the tps and all sorted, could be your issue maybe ? Quote
spoon Posted December 5, 2014 Posted December 5, 2014 it was the throttle that was mashed on mine sorted now Quote
