Ep911-20v Posted August 13, 2014 Posted August 13, 2014 Hi thought I'd share my starlet I'm from sydney australia and jump on your site time to time for ideas and other stuffIt's a ep91 starlet Converted to ae111 blacktop 20vEngine:Ae111 front cut including engine,loom and gearboxCustom alloy airbox housing k&n pod filterCivic alloy radiator,shroud and spal fanHks headers and front pipeHigh flow catGlanza jasma cat back Brakes:Non abs gt starlet front calipers and discsRda dimpled and slotted rotorsEbc green stuff padsGt starlet rear disc brake conversionWheels:14x6 genuine wantanabeSuspension:Lowered king springs (soon to be bc coilovers)White front 22mm anti roll barWhite line 20mm anti roll barInterior:Ae111 cluster (from front cut)Trd short shift kit and gear knob Nardi wheelPivot micro shift lightStock seats (soon to be recaro sr3)Will post up pics when tap talk starts working for me Quote
morgey Posted August 13, 2014 Posted August 13, 2014 Welcome to the uk 20v club. Only 4 of us on here afaik. Be good to see some pics, some close ups of how you mounted your engine would be good to compare too. Quote
Ep911-20v Posted August 13, 2014 Author Posted August 13, 2014 Yeah that's why I figured I'd post up on here not many around with this conversion Quote
Ep911-20v Posted August 13, 2014 Author Posted August 13, 2014 More photos a lil later im runnin late to work Quote
morgey Posted August 13, 2014 Posted August 13, 2014 You managed to squeeze the plenum in too I see. I think yours is a bit more forward than mine plus youve used the 20v mount or a variation of on the drivers side. I wish I had done mine that way now. Quote
Ep911-20v Posted August 13, 2014 Author Posted August 13, 2014 Ae111 orange face cluster Autometer oil pressure and water temp gauges (came out of my 180sx)Glanza door handles with power windows (aus spec doesn't have power windows)All wiring is there and switches for fold in mirrors to just need the mirrorsFactory option cup holders New front brakes fitted last weekEngine is solidly mounted using factory starlet mounts with insertsFitting up eunos 15x6 wheels with advan semi slicks 225/50 front 205/50Hoping to hit the track end of this month but also flyin out to mexico a few days after so dunno if ill make it Quote
Ep911-20v Posted August 13, 2014 Author Posted August 13, 2014 The drivers side mount has a slanted plate under it to tilt the motor slightly forward will get a detailed photo soon Quote
Ep911-20v Posted August 13, 2014 Author Posted August 13, 2014 You managed to squeeze the plenum in too I see. I think yours is a bit more forward than mine plus youve used the 20v mount or a variation of on the drivers side. I wish I had done mine that way now.Have to run the plenum and all the emissions gear to pass "engineering and EPA" testing in aus or your get slapped with defect notices "exhaust and emissions to comply" so it's a pain Quote
Ep911-20v Posted August 14, 2014 Author Posted August 14, 2014 Ohhhhh Exterior: Glanza tailights? (Correct me if I'm wrong) or the diesel model lights Paint work was ruined resprayed it and it didn't turn out great so I coated it in camo green plati dip Quote
Ep911-20v Posted August 15, 2014 Author Posted August 15, 2014 Next up is Recaros door inserts and strip out the rear interior Trying to find a renault Laguna splitter (extremely hard in aus) Coilovers Front door speaker pods 15x7s Hopefully soon Quote
Ep911-20v Posted August 25, 2014 Author Posted August 25, 2014 Removed the air conditioning but wanted to retain the power steering so had to change the flat tensioner for a ribbed pulley and run the belt under it Then had to make the tensioner pull down not up Put a nut and spring washer on either side of the bracket The top nut is to lock it and bottom nut showed in the photo is to tighten the belt as well as the original adjuster bolt Blitz reservoir socks Quote
Ep911-20v Posted August 25, 2014 Author Posted August 25, 2014 Pic of the back of the a/c bracket and tensioner set up Quote
FMuscle Posted August 28, 2014 Posted August 28, 2014 (edited) Nice to see I'm not the only one removing AirCon in Australia... Oi Mate! Quick question, what's that rad off? It's not the civic one from the other pics, what car is it from? Do you still have it and willing to sell?Cheers!. Edited August 28, 2014 by FMuscle Quote
Ep911-20v Posted August 30, 2014 Author Posted August 30, 2014 Nice to see I'm not the only one removing AirCon in Australia... Oi Mate! Quick question, what's that rad off? It's not the civic one from the other pics, what car is it from? Do you still have it and willing to sell?Cheers! Hay as far as i know it is a civic radiator not sure what engine or chassis it's from possibly ek I could sell it to you but the core is not in good shape The alloy rad I have in there now was $100 from eBay rad,fan and alloy shroud no use of a rad without a shroud! Quote
Ep911-20v Posted August 30, 2014 Author Posted August 30, 2014 Saving up for a set of these bad boys to fit inside the plenum chamber Sq engineering in Victoria Australia make them and claim they out flow toda and imec trumpets and add 7-9kw at the wheels across the rev range from 3200 rpm onwards Quote
morgey Posted August 30, 2014 Posted August 30, 2014 They fit inside the chamber? Number 1 would be seriously restricted from flow i would of thought. Quote
FMuscle Posted August 31, 2014 Posted August 31, 2014 Hay as far as i know it is a civic radiator not sure what engine or chassis it's from possibly ekI could sell it to you but the core is not in good shapeThe alloy rad I have in there now was $100 from eBay rad,fan and alloy shroud no use of a rad without a shroud! Well if the core is bad, I'll get the Suzuki GTi 2 core I found for $74. A civic one doesn't have the top hose where I want it, plus I'd hate to say I have honda parts on my car... lolCheers mate Quote
Ep911-20v Posted August 31, 2014 Author Posted August 31, 2014 They fit inside the chamber? Number 1 would be seriously restricted from flow i would of thought.Number one comes slightly modified you just tell them if your running them in the chamber and they put that into the process when making them ill post up there website so you can have a look Quote
Ep911-20v Posted August 31, 2014 Author Posted August 31, 2014 Well if the core is bad, I'll get the Suzuki GTi 2 core I found for $74. A civic one doesn't have the top hose where I want it, plus I'd hate to say I have honda parts on my car... lolCheers mateI'm in sydney your in wa right? wouldn't the shipping plus a new core out weigh the price of a new one? There's a mob in sydney called suzitech they do absolutely everything to do with modding swift gtis they no doubt will have a alloy one they'd ship to you under the price of fixing my old one?! Quote
Ep911-20v Posted August 31, 2014 Author Posted August 31, 2014 Number one comes slightly modified you just tell them if your running them in the chamber and they put that into the process when making them ill post up there website so you can have a lookhttp://s-86.com/velocity_stacks.phpIt's an extra $10 aud to machine number 1 to fit and flow Quote
DevonGT Posted August 31, 2014 Posted August 31, 2014 This is a really nice build, shall be keeping an eye on this. Quote
FMuscle Posted August 31, 2014 Posted August 31, 2014 I'm in sydney your in wa right? wouldn't the shipping plus a new core out weigh the price of a new one?There's a mob in sydney called suzitech they do absolutely everything to do with modding swift gtis they no doubt will have a alloy one they'd ship to you under the price of fixing my old one?! Yeah, Rockingham just South of Perth. I bought mine from Melbourne (eBay) earlier today, $74 delivered for a GTi 2 core alloy rad, not bad considering a stock replacement is 400+ in stores. Quote
Djaniero Posted September 1, 2014 Posted September 1, 2014 Cool build man. Where abouts in Sydney are you from? I used to live in the Eastern Suburbs.....never saw any starlets while I was there ....a good few scoobies and evos though. Quote
