Ep911-20v Posted September 1, 2014 Author Posted September 1, 2014 Cool build man. Where abouts in Sydney are you from? I used to live in the Eastern Suburbs.....never saw any starlets while I was there ....a good few scoobies and evos though.. Kings cross actually there's a fair few getting around nowYeah, Rockingham just South of Perth. I bought mine from Melbourne (eBay) earlier today, $74 delivered for a GTi 2 core alloy rad, not bad considering a stock replacement is 400+ in stores.Yeah I paid 100 bucks all up for my set up Quote
Djaniero Posted September 1, 2014 Posted September 1, 2014 Only a few stops from me ....I was in Bondi. I'll keep my eyes peeled on my next trip back there. Quote
Ep911-20v Posted September 5, 2014 Author Posted September 5, 2014 . Kings cross actually there's a fair few getting around nowYeah I paid 100 bucks all up for my set upYep some company I got my set up They were good to deal with and had it to me in 2 days might take a bit longer for you to get it though Quote
Ep911-20v Posted September 5, 2014 Author Posted September 5, 2014 Me and a friend went halves in this 180sx about a year ago Sr20det Gt2871r Bride seats R33 brakes all round and lots of other awesome mods.....anyway he did 12.8 second 1/4 mile while I was on holidays with a rich tune and some cheap shit tyres with better tyres should run flat 12s if not lower very happy with such a cheap investment (bought the car at a rediculous low price) it also does some very respectable lap times on street tyres next up is semi slicks Quote
NewbieLewby Posted September 7, 2014 Posted September 7, 2014 nice build man!!those Wantanabes are GORGEOUS Quote
Ep911-20v Posted September 10, 2014 Author Posted September 10, 2014 Thanks They are good and genuine but not wide enough ill be keeping them for street wheels for sure Quote
Ep911-20v Posted September 20, 2014 Author Posted September 20, 2014 New shoes!In desperate need of coilovers to drop it some more and cause my front shocks are near deadFound some interesting info on adjusting the fuel pressure from 40psi up to 44psi for some more low to mid range acceleration so gonna give it a go and see what happens Quote
mikey4410 Posted September 27, 2014 Posted September 27, 2014 Love this.what sort of power you producing ? Quote
Ep911-20v Posted September 28, 2014 Author Posted September 28, 2014 So roughly 120hp at the wheels with factory ecu and factory trumpets Quote
Ep911-20v Posted October 3, 2014 Author Posted October 3, 2014 Delivery for today New genuine toyota :Oil filler cap Valve cover gasket Distributor cap Distributor button And had top gun leads made up with dual spiral core rated upwards of 315 degrees Celsius With the same performance as 9mm or 10mm thick leads that fit in factory holders Next up is tomei fuel pressure regulator (when it finally arrives apparently australia post lost it ....... Yeah) And only a couple more weeks till coilovers get ordered Quote
morgey Posted October 3, 2014 Posted October 3, 2014 Not a bad figure, was about what mine made with just an exhuast.Decent manifold and a set of trumpets bagged me about another 10whp and cams made another 6whp still running the auto ecu. I could probably do with giving my dizzy an overhaul now I've seen this! Quote
Ep911-20v Posted October 3, 2014 Author Posted October 3, 2014 You really should ill post pics of the old cap and button Trumpets are on the list next spoke to sq again after you asked about the restriction on the trumpets in the plenum morgey They tell me they have tested the sh$t out of them and haven't found any so I'm gonna give them a go How's your driveability with those cams?? What's the degrees? Did you retain vvt? I seem they are tomei Pom cams I think? And no problems with the factory ecu? I'd read through your build but it's massive Quote
morgey Posted October 3, 2014 Posted October 3, 2014 You really should ill post pics of the old cap and button Trumpets are on the list next spoke to sq again after you asked about the restriction on the trumpets in the plenum morgey They tell me they have tested the sh$t out of them and haven't found any so I'm gonna give them a go How's your driveability with those cams?? What's the degrees?Did you retain vvt? I seem they are tomei Pom cams I think?And no problems with the factory ecu?I'd read through your build but it's massive If you could. I did look at mine and they looked a bit pitted but not too bad.I've looked at them sq ones and some reviews and they seem to be spot on. Well worth the money it would seem.Drivability is okish theres a flat spot around 3k or vvt change over. I think it needs mapping out but it is bareable and after 3k it revs out fine. Had the fueling checked and its still spot on.Vvt remains yes.Tomei poncams 264 256 not sure on lift maybe around 9mm? Not sure which duration is inlet and exhaust though. Quote
Ep911-20v Posted October 3, 2014 Author Posted October 3, 2014 After doing all the leads and dizzy freshen up its just alot smoother ive seen the quality before on their coolant block kits for rwd set ups their machining is very good Ill look into cams a lil later was just worried about how it drives down low mostly as it's my daily drive to work and back is roughly 60 something kms With speed cameras down most of the roads I use Was originally thinking of leaving the engine internals factory but I'm not getting rid of the car anytime soon Quote
Ep911-20v Posted October 3, 2014 Author Posted October 3, 2014 Just looked on tomei USA website I shouldn't have asked....... Now I'm gonna be burning till I get a set Quote
morgey Posted October 3, 2014 Posted October 3, 2014 Theyre not too bad to fit. Took an afternoon including checking clearances before and after i only dropped these in on the oem pulleys so probably not as setup as they could be. Only thing i forgot to do was put some sealant in and around the cam and endcaps so have a slight oil leak. In terms for cost for power these are around £500 here and mapped can see upto 12-15whp. My manifold, trumpets and filter cost about the same and gained around 10whp aswell. Quote
Ep911-20v Posted October 3, 2014 Author Posted October 3, 2014 It's already fitted with hks 4-2-1 manifold but gonna do trumpets and see how I go first need to sort my suspension out first but cams should be on the cards later Quote
morgey Posted October 3, 2014 Posted October 3, 2014 Yeah id defo sort your handling 1st. Are you running p/s or is yours a manual rack? Quote
Ep911-20v Posted October 4, 2014 Author Posted October 4, 2014 P/a at the moment but thinking of gettin rid of it But like I said it's the daily driver Quote
Ep911-20v Posted October 11, 2014 Author Posted October 11, 2014 Fuel reg all fitted up didn't get to test it much but it does seen to pick up better Quote
Ep911-20v Posted October 12, 2014 Author Posted October 12, 2014 Stopped by my mates house to check out his wife's new ride And thought it would be worth a shareMazda rx7 1982 series 2 on the leftRunning 13b ported for turbo but running n/a with injection perfection webber style manifold ground up restoration Discs brakes all round On the right is a 1973 mazda rx2 sedan Running 12a turbo all factory inside an out not the original motor but clean enough to eat off both cars Rx2 to be featured in next months fast 4s and rotaries magazine Quote
Ep911-20v Posted October 19, 2014 Author Posted October 19, 2014 Went to world time attack sydney on sat just one pick took a heap of videos dunno how to post them Videos of the mazda 787b Le Mans car down the main straight And "mad mike" widdets "madbull" 26b rocket bunny kitted fd rx7 drift car if you've never heard of him YouTube Mad mike crown range rediculous machine Quote
Ep911-20v Posted November 7, 2014 Author Posted November 7, 2014 Small update vinyl died my door card inserts today using duplicolour fabric and vinyl die in flat black Unfortunately stupid tapatalk won't let me upload pics! Looks much better gonna be puttin in black swift gti seats soon hopefully this weekend! If this guy comes and buys my spare gearbox Quote
