Ollieh17 Posted August 14, 2014 Posted August 14, 2014 (edited) Quick question, when you install a emanage blue with a 3 bar map sensor, how do you go about fitting it. Do you leave the standard map sensor plugged in? Edited August 17, 2014 by Ollieh17 Quote
abbie Posted August 14, 2014 Posted August 14, 2014 just a vacuum pipe from 3 bar to inlet think you take the standard one out but I cant remember 100% Quote
german4efte Posted August 14, 2014 Posted August 14, 2014 standart one is also fitted. greddy one is seperat. Quote
Ollieh17 Posted August 17, 2014 Author Posted August 17, 2014 Installed both maps and installed my self wired harness and the car wont start. It is mapped to td04 at a bar from previous owner and was going to fit it and get the mapped tweaked for my set up. I thought the car will still start on a emange even with no map etc. before i rip all thr wiring apart again is it likely to be the map? Green light comes on on the ecu and so does the orange imteraction light Quote
Ollieh17 Posted August 21, 2014 Author Posted August 21, 2014 Still having an issue. Car runs fine with the field harness plugged in to the standard ecu aslong as the emanage harness isnt plugged into the emanage ecu. Soon as i plug the e harness into the e ecu the car wont start Quote
Duduglanza Posted August 26, 2014 Posted August 26, 2014 (edited) There is something wrong.. you need to check all parameters and zero outthe ignition and injector table. If this doesnt work .. you have someting in the wiring. Edited August 26, 2014 by Duduglanza Quote
