FMuscle Posted August 17, 2014 Posted August 17, 2014 (edited) I just want to know how you high powered Starlet Owners do your daily driving. When people see/hear about my engine, I get comments like "You're gonna get airborn" and "You wont be able to keep traction"I know some of you have well over 300hp, I'm looking at about 200 on paper... My Car weights 897kg as we speak, shouldn't change much after the swap. Edited August 17, 2014 by FMuscle Quote
MARC MOSS Posted August 17, 2014 Posted August 17, 2014 It's only as fast as you press the pedal mate, turn the boost down a little if you are worried lol200's fuck all to worry about anyway mate that's normal bottom end power for this lot. Quote
FMuscle Posted August 17, 2014 Author Posted August 17, 2014 200 will only be when the SC14 is switched on. I'll be running N/A with the bypass open most of the time, at about 120-125. And all numbers are theorical calculations... Quote
5e colin Posted August 17, 2014 Posted August 17, 2014 more like 110 if the na block is high compression with headwork if it has low comp pistons then probly 85 to 90 bhp what boost will u be running with the charger ???? Quote
daniel_g Posted August 17, 2014 Posted August 17, 2014 5E with bolt ons 120 sounds about right in N/a form Quote
