Browner Posted August 20, 2014 Posted August 20, 2014 Ok guys... I finally got my Glanza back up and running with lots of new mods... But now I have with a problem...I am running very big power but the handling is all over the place and quite frankly dangerous. I have fitted wider vented wings to the front and the wheels (15" Rota Grids) are lost underneath. The rear arches are standard. I used 25mm spacers all round and the wheels look good and sit well in the arch but now the handling is all over the place.I have new polybushed wishbones to fit and a new Whiteline front anti roll bar with Polybushed Droplinks. I am running brand new BC Coilovers all round and an adjustable Whiteline Panhard rod on the back. Basically I have to lose the spacers and set up the suspension properly I think. I was reading up and offset of standard OEM Glanza alloys is et38. I want to run a wide wheel maybe 8 or 8.5s? I have found wheels I like and was thinking an offset of et13 and the appropriate width would give the same effect as the spacer but be a lot safer and more solid on the road. Would this offset be correct? And what is the widest wheels I could run front and back without issues? I don't want to roll the rear arches as I only resprayed the car (again!) lolThanks in advance guys... Love you lotsBrowner Quote
_shaun_ Posted August 20, 2014 Posted August 20, 2014 I run 8j et25 wheels with just my arches rolled and have no issues if thats any use Quote
dj-rix Posted August 21, 2014 Posted August 21, 2014 Get your wheel alignment done with the spacers fitted Quote
MARC MOSS Posted August 21, 2014 Posted August 21, 2014 15x7.5 et 36 all the way mate if you want it to handle maybe an 8-10 hubcentric on the front with some negative camber dialled in if you are tracking it... Quote
Browner Posted August 21, 2014 Author Posted August 21, 2014 I'm terrible when it comes to offset and camber etc! LolMarc you reckon the widest I could go with would be a 7.5 then? Quote
MARC MOSS Posted August 21, 2014 Posted August 21, 2014 Max mate ,,, height is an issue as well it may slightly catch the rear though... Personally I feel the best setup is a 195/50/15 on a 15x7 with an 8mm spacer on the front with about 2.5 degree neg camber for the peel in when cornering. Quote
Browner Posted August 21, 2014 Author Posted August 21, 2014 Thanks for the help Marc. I'd say 7.5s then. Would 195/50/15's be too small a tyre for them? Quote
MARC MOSS Posted August 21, 2014 Posted August 21, 2014 Na they will be fine mate, setting up the geo and fitting the correct tyres will make a huge difference... Quote
Browner Posted August 21, 2014 Author Posted August 21, 2014 Once I know the widest wheels I can run I can order them up, swap the tyres over and then set up the Coilovers and tracking and camber etc. so you think 7.5 with 13 offset should be ok? I wouldn't get away with 8's no? The wider the tyre the more grip... :/ Quote
TrisK Posted August 21, 2014 Posted August 21, 2014 I reckons 8s would work. As long as the offset is 10-30Although if your particularly low you'll have issues and would be safer with a 7 or 7.5 Quote
Browner Posted August 21, 2014 Author Posted August 21, 2014 Well I can run whatever height I have to, to suit the wheels but from the feedback I've got and from what I can read elsewhere online it seems 7.5's would be the best option. Quote
