  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
need to try find another ecu to try. Wouldn't a faulty injector cause it to be rich all the time? Under a bit of load the afr starts to lean out then off the throttle goes rich again
Tried another lambda and its made a difference. Crusiing it holds 15 now. But when revved up to like 3k it goes real lean stutters then drops and pulls fine.
So just to confirm, your on stock ecu only, have set tps and timing to stock? Stock fpr and injectors? Tried a reset of the ecu and checked for diag codes?
