5e colin Posted August 26, 2014 Share Posted August 26, 2014 (edited) hey lads i need the 3 male ecu plugs from a ep91 with a bit of wire left on it and i need a female 2 plug from 4efe/4efte ecu Edited August 28, 2014 by 5e colin Link to post Share on other sites
rob_bower Posted August 26, 2014 Share Posted August 26, 2014 might have all that lying about ill try and ahve a look Link to post Share on other sites
5e colin Posted August 26, 2014 Author Share Posted August 26, 2014 tanks pm me a price on them bits going trying to fit glanza v ecu in my gt ?????? cheers 5e colin Link to post Share on other sites
Gainzy Posted August 26, 2014 Share Posted August 26, 2014 Pm'd you for the lot Link to post Share on other sites
5e colin Posted August 27, 2014 Author Share Posted August 27, 2014 bump Link to post Share on other sites
Stu Posted August 28, 2014 Share Posted August 28, 2014 Find an old ecu and chop the plugs out of it - i've done this many many times Link to post Share on other sites
5e colin Posted August 28, 2014 Author Share Posted August 28, 2014 to expensive in the scrapyards over ere they want 60e just for the na ecu , there well off there rocker cover !!!!!! Link to post Share on other sites
5e colin Posted August 28, 2014 Author Share Posted August 28, 2014 male and female from the ep82 sorted al i need now is the 12 pin male socket from the glanza ecu Link to post Share on other sites
pockrockgtti Posted August 28, 2014 Share Posted August 28, 2014 http://uk.rs-online.com/web/p/pcb-connector-housings/7201005/ Link to post Share on other sites
pockrockgtti Posted August 28, 2014 Share Posted August 28, 2014 This is the 12 pin plug. http://uk.rs-online.com/web/p/automotive-connector-accessories/7201036/ you need to order the crimps seprate aswell Link to post Share on other sites
5e colin Posted August 28, 2014 Author Share Posted August 28, 2014 ^^^^ hey thanks mate much appreciated any chance you can link the crimps aswell thanks 5e colin Link to post Share on other sites
pockrockgtti Posted August 28, 2014 Share Posted August 28, 2014 Pins im not so sure about. Have a look at this tableThere are two diffrent size pin for these connectors. And then within the two diffrent pins theres various diffrent options for cable sizes aswell, all the part numbers are on the table above. Just put them in the search box on rs components. Link to post Share on other sites
