Could use Any info / Pictures on quilif diffs , , i Bought a gearbox some time ago thinking It Was qualif, , i van see through where the shafts would go and It is rifled! So Im sure its not standard however if i jack It up Put It in neuteral and Turn One wheel , the oposite wheel goes the other way , Just a Bit confused
Only some diffs spin the other wheel the same way. some need an input torque to lock both together.
Open diff is a 10mm pin across the hole
Then others are plates or plates with holes in them depending on brand
