So I was wondering if any work would need to be done on my Glanza to fit Rota Grid Drifts? I'm currently running TE37 replicas which are 16x6.5j and have no problem with rubbing. My problem is If I need to roll arches I'm buggered as I have LiveSport Overfenders all around :/
Cheers people! Bret.
nah im just grids on front of mine and grid vs on back...
the drifts are alot more concaved.
iddy had them on his yellow glanza...
think you do need them rolled or wider front wings for the grid drifts thow.
Aghh okay mate thank you. And don't the Grid V's rub on the back at all? I don't know what wheels to go for that's all. Have you got a photo of yours?
Bret.
not best of pic
but the grid v is 15x7 et 20 i run a 195/50/15 and the back needed rolling cus they rubbed like f**k
15x7 et 40 on the front with 5mm spacer.. need to b spaced more thow at some point.
Aghh I don't know what to do now :( I want the Grid Drifts or V's but don't want to roll arches cause of the fenders. Here's mine at moment. Nice looking glanza too by the way :) Looks in good nic!
Bret.
cheers mate. try keep it up together :-D
do the livesports archers have a lip that sits over the original wing lip?
cus only had to roll the lip up.
Edited by fordie_glanzaV
I'll have to go and check again tomorrow. But If I remember rightly it sits level with the original arch lip. Which is the problem as I can't roll the fenders obviously :( Don't really know what to do..
Bret.
Yeah I could always run a little stretch on the Grid V's or drifts that's something I was thinking about. But to be honest I don't know much about alloy sizes or tyres though lol. So didn't know if it was gonna be possible at all..
Bret.
So after a little think about it.. Will anyone be able to let me know if I'll be able to run any rota wheels without rolling the arches or If I'll be able to get away with lower profile tires? Or If I will with a bit of stretch?
Thanks lads, Bret.
You can run any wheels at all without rolling the arches. It's when you look at 15x8 where you might start to roll arches. 15x7 and below would be fine with 195/50/15's
That is spot on :)
James
Stock suspension? Or a small drop though.. If it's going to be as low as his Glanza they won't fit
Trd shocks and springs obviously the front ain't low as no engine atm, but just set the coilys at the right height and won't rub
I think Gt's can have wider wheels without rolling arches from what i've read before?
Now I've got to choose the wheels I'm wanting lol. I've got three options at the moment which are really sticking out to me. Bare in mind I have a Silver V which type of wheel and what colour you guys think will look the best. :)
Rota Grid V's 15” x 7.0” 4x100 ET20 - Easy to source but becoming fairly common..
Genuine Ray Volk TE37 15" x 6.5" 4x100 ET37 Rare in 4 stud pattern, look awesome, very light. But will look the same as my car currently does and are pretty damn expensive!
Enkei RPF1 15" x 7" 4x100 ET40 Look sweet but never seen them on a glanza? Found a few sets and I believe fairly light?
Any other alloy you recommend?
Thanks again, Bret. :)
