Not sure if this is the correct section for this so I apologise if it is not. I've noticed that whenever I am driving my water temp gauge is always quite low by the C. But as soon as I stop it will move to the middle like it is supposed to. Radiator fans kick in if it gets to hot like they should and get hot air from the heaters (could be hotter, set to 30°c and its warm not hot). Anyone seen this before? Or things to check should I be worried haha?
Put the thermostat in a cup full off water and put in the microwave for 2 mins easy way to see is it working
I for some reason don't think it's a good idea putting a metal thermostat in a microwave...
Ive opted out of the microwave and decided it was much safer to heat the thermostat up with a lit firework at my local petrol station!
Ordered a new one from Id workz waiting for it to arrive :)
Mines the same driving round normal it'll sit 1/4 of the way until give it the beans then it sits at normal and the fan will kick in... but if I don't boot it, it stays low unless sat idling
