Is there any way to spot a jam actuator, I was looking in a bucket of parts I got with the gt and there's a gold actuator by its self and the one ok turbo is silver, I Googled it and seen jam ones ten to be gold is this correct?
Edited by Glanza-Ben
Jam has two stems so to speak, best way to tell is take that silver one off and compress both of them with your hand, the Jam one has the stiffer spring load some stock actuators have small stickers on the bottom if I was there I could guarantee you to two seconds lol
I did check the strength of it and seem quite solid, I will check against the other tomorrow, chances are it is as found a lot of little jdm bits on it
