Give Mike at tuning developments or idress a PM. I'm sure they will be your best bet mate.
There was a set of Pistons in the for sale section and a set of Max speed rods aswell.
Hi lad, I've a forged bottom end going cheap as it needs 1 piston replaced.
It's got
74.5mm cp pistons
Scat rods
Acl bearings
Polished crank
Engine block
It's been running for a couple of years, but I recently changed injectors and burnt a hole in one of the pistons!
So it would need one new cp piston to get back up and running.
Block and bore are mint the piston went right in the middle so no damage at all anywhere else.
Now if I'd the money id et onto cp and order a piston and sell the engine for 1500quid
But I don't have the dollar.
Acl bearings and thrust washers are 120
Cp pistons 500
Scat rods 300
Good crank block and machine work to match priceless lol
Looking 550 plus pallet cost (45quid)
Let me know if interested before I stick it up forsale or stick it on the backburner till I can sort it myself.
Cheers
Phil
I have a set of brand new forged rods for sale there. The brand isn't really known but they have been used and tried before without fail and they work great.
Send me a offer through sure you never know what you could get them for.
It's got
74.5mm cp pistons
Scat rods
Acl bearings
Polished crank
Engine block
Cp pistons 500
Scat rods 300
Cheers
Phil
If they guys who have shown an interest in this offer want to get in touch i have decided i will consider letting the engine go at this money.
i am wanting to get head work done and can warrant the cost of fixing this now to make an extra 300 or something quid.
Cheap forged engine for someone.
Machinework/bearings/rods all 100% needs 1 new piston, or a set of pistons.
Phil
  • 2 weeks later...
It's got
74.5mm cp pistons
Scat rods
Acl bearings
Polished crank
Engine block
Cp pistons 500
Scat rods 300
Cheers
Phil
hi Phil if you ever decide to split the bottom end i would take the scat rods off you.
Kevin
