crispyeel Posted September 28, 2014 Posted September 28, 2014 Hey folks hopefully someone can help me out here Myself and a mechanic friend were trying to fit my new HDI FMIC to my 1999 EP91 Glanza but was having some issues and had to give up Problem that we had was that the pipe that goes from the turbo down past the radiator and under the chassis leg doesn't seem to give enough clearance to clear the chassis leg/front panel area. Making it impossible for the next bend to attach without cutting away at this panel. Not really ideal Has anyone else had this issue fitting an HDI or am i doing something wrong?? Quote
Socks Posted September 28, 2014 Posted September 28, 2014 Have you got an aftermarket Manifold? Quote
maddox710 Posted September 28, 2014 Posted September 28, 2014 I had to get Gary the grinder out when mine was running ct9 Quote
teta Posted September 29, 2014 Posted September 29, 2014 cut to shorthen then reweld or use a silicone hose to join the 2 pieces together Quote
crispyeel Posted September 30, 2014 Author Posted September 30, 2014 (edited) Yeah thinking that's going to be my only option. Car is currently sitting in bits and really want to get cracking on Edited September 30, 2014 by crispyeel Quote
akyakapotter Posted September 30, 2014 Posted September 30, 2014 I'd just grind away the toe hook Quote
crispyeel Posted October 1, 2014 Author Posted October 1, 2014 (edited) Na don't want to be hacking away at the car. Just going to cut it and join with a silicone hose Edited October 1, 2014 by crispyeel Quote
