BillyLindsayEp82 Posted September 30, 2014 Share Posted September 30, 2014 Just bought my first ep82For some reason the fan is always on, making the car run cool, a lot less than half way on the temp gauge, is this going to cause problems, is there any advantages/disadvantages? Thanks Quote Link to post Share on other sites
morgey Posted September 30, 2014 Share Posted September 30, 2014 Theres a single wire plug under the dizzy that controls the fan. Either the sensors knackered or the wire is split. (Or not connected) If its running thay cold it might still be on cold idle so will be over fueling. Quote Link to post Share on other sites
mikey4410 Posted September 30, 2014 Share Posted September 30, 2014 Or somebody hasnt bridged the aircon sensor unit.that also makes fan come on permanent Quote Link to post Share on other sites
BillyLindsayEp82 Posted September 30, 2014 Author Share Posted September 30, 2014 Theres a single wire plug under the dizzy that controls the fan. Either the sensors knackered or the wire is split. (Or not connected) If its running thay cold it might still be on cold idle so will be over fueling.I've looked at that and it seems to be connected ok. And gets between the cold line and half way Quote Link to post Share on other sites
BillyLindsayEp82 Posted September 30, 2014 Author Share Posted September 30, 2014 Or somebody hasnt bridged the aircon sensor unit.that also makes fan come on permanentThis could be the reason as air con has been removed, how would I check for this? Sorry I'm new to these cars Quote Link to post Share on other sites
Stu Posted October 6, 2014 Share Posted October 6, 2014 Just behind the passenger side headlight, should be a grey plug with two wires - wires need bridging/joining Quote Link to post Share on other sites
BillyLindsayEp82 Posted October 6, 2014 Author Share Posted October 6, 2014 got it! will it cause any problems if i keep the fan running? car doesnt reach half way on gauge. thanks Quote Link to post Share on other sites
Socks Posted October 6, 2014 Share Posted October 6, 2014 Its best to keep the fan off unless its needed. Quote Link to post Share on other sites
