glanzatd04l220 Posted October 11, 2014 Share Posted October 11, 2014 what i'm lookin to know is will the td04l be able to make 250hp on forged engine? what boost will i have to run to achieve this figure? thanks kevin Quote Link to post Share on other sites
5e colin Posted October 11, 2014 Share Posted October 11, 2014 about 1.4 depends on spec and engine condition Quote Link to post Share on other sites
glanzatd04l220 Posted October 11, 2014 Author Share Posted October 11, 2014 so the td04l would be at its max boost so would be better of getting a td05 then. kevin Quote Link to post Share on other sites
5e colin Posted October 11, 2014 Share Posted October 11, 2014 no not at its max they take a bit more then that i would buy an o5 anyway you will make the same bhp at lower boost and it will pull harder Quote Link to post Share on other sites
Ollieh17 Posted October 11, 2014 Share Posted October 11, 2014 Most people get 230-240 at 1bar on a td04...1.4 is normally 260-270ish Quote Link to post Share on other sites
mikey4410 Posted October 11, 2014 Share Posted October 11, 2014 A td04L will make circa 220-230 on a good health engine dude.so ure magic 250 aint much more boost .1.1 and I think that wud give you 240.Do that and be done with it.afaik the stock injectors arent to happy past 220 bhp.got told that a few times. Quote Link to post Share on other sites
glanzatd04l220 Posted October 11, 2014 Author Share Posted October 11, 2014 thats good to hear so i can keep the td04l, mikey4410 im using the standard injectors running 1 bar at 215bhp but i've bought some 430cc injectors for when i go forged. kevin Quote Link to post Share on other sites
mikey4410 Posted October 11, 2014 Share Posted October 11, 2014 Bigger injectors im sure are a must,however you will need management to run those puppys Quote Link to post Share on other sites
5e colin Posted October 12, 2014 Share Posted October 12, 2014 Most people get 230-240 at 1bar on a td04...1.4 is normally 260-270ish depends on rollers in ireland its usually 210/220 at a bar Quote Link to post Share on other sites
glanzatd04l220 Posted October 12, 2014 Author Share Posted October 12, 2014 hi mikey4410 im running the e manage blue will that be able to run the 430cc injectors ok? kevin Quote Link to post Share on other sites
mikey4410 Posted October 12, 2014 Share Posted October 12, 2014 I wont lie mate.I dont know the answer to that.I would at a guess say yes.im sure somebody in the know can confirm or not. Quote Link to post Share on other sites
lew777 Posted October 12, 2014 Share Posted October 12, 2014 I'm running 296 @1.2 bar on my tdo4l Quote Link to post Share on other sites
5e colin Posted October 12, 2014 Share Posted October 12, 2014 ^^^^ printout Quote Link to post Share on other sites
glanzatd04l220 Posted October 12, 2014 Author Share Posted October 12, 2014 I'm running 296 @1.2 bar on my tdo4l you must be running a high comp engine to get them figures at only 1.2 bar? kevin l Quote Link to post Share on other sites
