Which is better? Also I know of a few guys who build the forged 4e but is there anyone who builds forged 5e's?
How difficult is it to do your self? I'm pretty mechanically minded but not built an engine before?
Any info would be great.
Depends what your gonna use it for?
Road/fast road setup then a 5E if you have access to one.
Drag again I would use a 5E.
Circuit/Time attack would prefer to use 4E.
my 5e build
£175 for engine
£750 for pistons rods and rings
£90 for oil pump
£140 for gasket set
£156.10 for acl shells and crank seals (TD)
£108.99 for head gasket (IDWorkz)
£63.99 for timing belt kit (ebay)
£110.40 ARP main stud and nut kit (TD)
£135 for ARP head bolts (IDWorkz)
£365 for machine work (re-bore, crank grind, reem little end pins, block deck, notch block and block clean)
= £2094.48
thats a rough price of what i just had done this year, but thats just for the basics, supporting mods, oil, filters, injectors etc..... were on top.
its not cheap, but well worth it
