Ashbash107 Posted October 12, 2014 Share Posted October 12, 2014 Which is better? Also I know of a few guys who build the forged 4e but is there anyone who builds forged 5e's?How difficult is it to do your self? I'm pretty mechanically minded but not built an engine before?Any info would be great. Quote Link to post Share on other sites
5e colin Posted October 12, 2014 Share Posted October 12, 2014 do a test build first mate buy an old running 4efe rip it appart clean it then start measuring ( studying ) and fit al back together and test it 1s u get the know how do a rebuild with new parts Quote Link to post Share on other sites
Ashbash107 Posted October 12, 2014 Author Share Posted October 12, 2014 Sounds good man, I was thinking it would be cheaper to build it yourself but a costly mistake if I don't do something right Quote Link to post Share on other sites
glanzatd04l220 Posted October 12, 2014 Share Posted October 12, 2014 you'll be grand building it yourself and if you got in to difficulty there's plenty of people on here to give you advice if you ever get stuck. kevin Quote Link to post Share on other sites
mikey4410 Posted October 12, 2014 Share Posted October 12, 2014 Mate its gotta be 5e.less revs but torque and power in essentially same size engine would be epic Quote Link to post Share on other sites
Phil Posted October 12, 2014 Share Posted October 12, 2014 5e for outright power.Forged either can rev very high despite the squared 4e being better suited theorticallyPhil Quote Link to post Share on other sites
Ashbash107 Posted October 12, 2014 Author Share Posted October 12, 2014 Anyone know roughly the kinda price you can build one of the 5e's for? With forged rods as well? Just roughly Quote Link to post Share on other sites
5e colin Posted October 12, 2014 Share Posted October 12, 2014 1000/1200£ +- diy you need rebore to Quote Link to post Share on other sites
AdamB Posted October 15, 2014 Share Posted October 15, 2014 Depends what your gonna use it for?Road/fast road setup then a 5E if you have access to one.Drag again I would use a 5E.Circuit/Time attack would prefer to use 4E. Quote Link to post Share on other sites
rwdrev Posted October 16, 2014 Share Posted October 16, 2014 my 5e build £175 for engine£750 for pistons rods and rings£90 for oil pump£140 for gasket set £156.10 for acl shells and crank seals (TD)£108.99 for head gasket (IDWorkz)£63.99 for timing belt kit (ebay)£110.40 ARP main stud and nut kit (TD)£135 for ARP head bolts (IDWorkz)£365 for machine work (re-bore, crank grind, reem little end pins, block deck, notch block and block clean) = £2094.48thats a rough price of what i just had done this year, but thats just for the basics, supporting mods, oil, filters, injectors etc..... were on top. its not cheap, but well worth it Quote Link to post Share on other sites
