bought a 5e engine the other night and the owner said it was a 5efe, just looking to know how do you tell the difference between the 5efe and 5efhe rods.
heres some photos of the rods that came out of the engine.
kevin
so these are the rods that can stand a right bit of boost? how much would they be worth?
kevin
Yes these rods are very reliable you can accept higher boost ...
kevin
Price wise probably about £130 ish. Problem being is that if people are going 5E and they open up the engine they are more likely to forge rather than stick an OEM item in unless they are doing a budget build.
gen1 5efe and 5efhe rods are impossible to tel apart unles they come out of a unopened engine you will never know both will hold boooost
its the same with gen1 4efe and 4efte rods there is no way to tell them apart neither
price wise 120euros for a set of 5efhe rods aint bad
