Symo1995 Posted October 18, 2014 Posted October 18, 2014 Just got starlet sportiff already with the conversion not yet completed rear loom for lights, the car starts ticks over but cuts out when you touch throttle anyone got any ideas on what it could be Quote
Ryan5793 Posted October 18, 2014 Posted October 18, 2014 I've just done a conversion and mine hunts when you press the throttle lightly so think i might have a dogey tps sensor, could give that ago bud Quote
GlanzaJ Posted October 18, 2014 Posted October 18, 2014 maybe a vac leak mate , check the small hoses around the bay, intercooler connections, and make sure the bolts are up tight on the inlet and throttle body ? Quote
Symo1995 Posted October 19, 2014 Author Posted October 19, 2014 Ok lads cheers I will give these things ago after work 2moro and let you know, I have a glanza anyway so can swap the bits over an try them ! Will let you know the results Quote
Symo1995 Posted October 20, 2014 Author Posted October 20, 2014 It's sorted lads it was because the greedy boost cut was wired in but not wired to the power also couple vac pipes not sure what there for but they weren't connected, I did try just the vac pipes but still no good so connected power to this greedy boost cut controller an she now revs fine, I haven't taken it for spin yet so I will know if it's all good by the weekend will keep you posted Quote
mikey4410 Posted October 20, 2014 Posted October 20, 2014 Yeah let us know how she runs etc !!!!! Quote
Symo1995 Posted October 21, 2014 Author Posted October 21, 2014 I will do mate read you build fair play it's a beast Quote
Symo1995 Posted October 21, 2014 Author Posted October 21, 2014 So I went and done a few bits on the sleeper after work an I tried the lights but only the front low beam works none others eg front or back indicators or rear lights! Was abit dark so was using a lamp I will get into it in the weekend and see if I can sort these lights out Monkey did you have any problems with any lights or ? Mikey* Quote
GlanzaJim Posted October 22, 2014 Posted October 22, 2014 The front indicators did work, it was the rear lights and rear indicators. The rear brake lights work Quote
Symo1995 Posted October 22, 2014 Author Posted October 22, 2014 Ahh ok buddy cheers how do you know that mate lol ? Are you the lad that come over with Wayne ? Or one of his mates, do you know what I should do to try fix them ? Quote
GlanzaJim Posted October 22, 2014 Posted October 22, 2014 (edited) I done the conversion with wayne, that was josh his other mate who was with him. cant beleve it was something simple as that. Tried everything lol. Down the side under the plastic is 2 plugs. They run to the rear loom, buy a glanza rear loom and put it in. Easiest option. You taken it for a blast yet Edited October 22, 2014 by GlanzaJim Quote
Symo1995 Posted October 22, 2014 Author Posted October 22, 2014 Ok mate thanks for that, yh I know I bet he's gutted was a very easy fix how long were you lads tryna sort it lol ? I haven't taken it for spin yet mate will do on the weekend Quote
GlanzaJim Posted October 22, 2014 Posted October 22, 2014 Well About 9 weeks lol. Just couldnt find out what it was. Went to numerous garages and they didnt even know. id like to know if it goes alrite tho lol Quote
Symo1995 Posted October 22, 2014 Author Posted October 22, 2014 I will post up here straight away when I've taken it out buddy there's a few more little things that need bolts in exct an the indicators an horn but it has not ATM anyway so the horn isn't a must or the high beam front lights ent working low beam does though I will have it sorted by the weekend hopefully been going over to the car each night after work an doing few things get it done an on the road Quote
Symo1995 Posted October 22, 2014 Author Posted October 22, 2014 I don't know how to upload them mate ? I'm in my phone Quote
Symo1995 Posted October 22, 2014 Author Posted October 22, 2014 There's pics of it on the for sale bit as I inly got it Sunday it's says white starlet sportiff unfinished project I think There's pics of it on the for sale bit as I inly got it Sunday it's says white starlet sportiff unfinished project I think Quote
GlanzaJim Posted October 23, 2014 Posted October 23, 2014 Ahh sick man. Upload pics through photobucket mate Quote
Symo1995 Posted October 29, 2014 Author Posted October 29, 2014 Can anyone give me some pics of the wiring for the fogs ? Quote
Symo1995 Posted October 29, 2014 Author Posted October 29, 2014 Still haven't taken it out yet an trying to get the lifts sorted so I can insure it an use it Quote
Symo1995 Posted November 3, 2014 Author Posted November 3, 2014 Right so everything is fixed just have to sort the tracking abit better as it's way out, an I will be taking it for a spin Quote
Symo1995 Posted November 5, 2014 Author Posted November 5, 2014 Yh everything is no fixed only thing I need to do it get the top lamber sensor in the decat as the fmic pipe work is in the way I took it for a spin was all fine no light come in the dash exct an went lily stink was all over the place though as trackin is miles out so will sort trackin next at get this lamber sensor in just gotta cut bit more of the fan casing out, the lights wernt easy lol but terraced the worse an had a look at the old dash loom and sorted them in the end Quote
