Adam M Posted October 22, 2014 Share Posted October 22, 2014 Hi all struggling to get rid of my airbag light bought some 3.9 ohm resistors and put them in the plug that comes out the steering wheelno joy tried resetting the srs light's using the 2 wires to earth sequenceno joy can anyone tell me how to get rid of it without buying a standard wheel/airbag? many thanks on any input Adam Quote Link to post Share on other sites
akyakapotter Posted October 22, 2014 Share Posted October 22, 2014 I'll have a look at mine tomorrow for you how what have you connector have you put the resister into? Quote Link to post Share on other sites
Whitenoize Posted October 22, 2014 Share Posted October 22, 2014 I just took the bulb out simples Quote Link to post Share on other sites
Adam M Posted October 22, 2014 Author Share Posted October 22, 2014 I put the resistor into the yellow 2 wire connecter that usually plugs into the steering wheel airbag @whitenoize will that pass the m.o.t ? as mine is due soon many thanks Adam Quote Link to post Share on other sites
Whitenoize Posted October 22, 2014 Share Posted October 22, 2014 Yes mate I've had no problems with mot they don't check to see if a bulbs in there or anything Quote Link to post Share on other sites
Adam M Posted October 22, 2014 Author Share Posted October 22, 2014 Ok cool I may just do that then! Still strange as seen a post on forums saying the resistor should work Quote Link to post Share on other sites
Whitenoize Posted October 22, 2014 Share Posted October 22, 2014 It should work but I just got the bulb out and forgot about it couldn't be bothered messing about lol Quote Link to post Share on other sites
Adam M Posted October 29, 2014 Author Share Posted October 29, 2014 @akyapotter did you manage to get a lookAt yours? Would be most gratefullMany thanksAdam Quote Link to post Share on other sites
akyakapotter Posted October 29, 2014 Share Posted October 29, 2014 @akyapotter did you manage to get a lookAt yours? Would be most gratefullMany thanksAdamWill do it possibly later for you bud as I have my little one today a she take up all my Time when she naps I'll have a look Quote Link to post Share on other sites
akyakapotter Posted November 2, 2014 Share Posted November 2, 2014 Here you go bud I had 2 air bags so used 2x resisters like this worked a treat comes on and goes off like it should Quote Link to post Share on other sites
Adam M Posted November 4, 2014 Author Share Posted November 4, 2014 Ok cool many thanks bud where is the 2nd plug located? Maybe i have to put on in there aswell Thanks mate Adam Quote Link to post Share on other sites
akyakapotter Posted November 4, 2014 Share Posted November 4, 2014 Under the dash where the dash top airbag is dunno if non air bag ones have that one maybe though. Quote Link to post Share on other sites
Ollieh17 Posted April 27, 2015 Share Posted April 27, 2015 Im also having the same issue.resistor isn't doing anything? Quote Link to post Share on other sites
akyakapotter Posted April 27, 2015 Share Posted April 27, 2015 Im also having the same issue.resistor isn't doing anything?3.9 ohm resisters are needed Quote Link to post Share on other sites
Ollieh17 Posted April 27, 2015 Share Posted April 27, 2015 Thats the ones ive got! Quote Link to post Share on other sites
christyep91 Posted April 27, 2015 Share Posted April 27, 2015 Mine is just done with a fuse no resistor at all Quote Link to post Share on other sites
Ollieh17 Posted April 28, 2015 Share Posted April 28, 2015 Mine is just done with a fuse no resistor at all explain bud? Quote Link to post Share on other sites
akyakapotter Posted April 28, 2015 Share Posted April 28, 2015 Fuse with 2 bits of wire soldered to it and put in like my resistor Quote Link to post Share on other sites
jimmymac101 Posted April 28, 2015 Share Posted April 28, 2015 http://www.demon-tweeks.co.uk/performance/centre-rings-accessories/simoni-racing-airbag-warning-canceller-kit This is what I used and it worked perfectly for me James Quote Link to post Share on other sites
jellybaby Posted April 29, 2015 Share Posted April 29, 2015 take the bulb out ???? simple that if u running a non air bag wheel Quote Link to post Share on other sites
jimmymac101 Posted April 29, 2015 Share Posted April 29, 2015 take the bulb out ???? simple that if u running a non air bag wheel Cant get an MOT without an airbag light Easiest thing to do is buy that kit i linked up above in my opinion James Quote Link to post Share on other sites
jellybaby Posted April 29, 2015 Share Posted April 29, 2015 Have u got air bag in place then or u got w after market steering wheel Quote Link to post Share on other sites
jimmymac101 Posted April 29, 2015 Share Posted April 29, 2015 air was removed when I took the standard steering wheel off and replaced with deep dish steering wheel The red cable you can see poking out the side of the boss kit is the air bag delete kit tucked inside the boss kit....... later moved it under the horn for better fitment James Quote Link to post Share on other sites
