chad94 Posted October 26, 2014 Share Posted October 26, 2014 hi guys, right.. as stated above im in need of some advice. i brought my ep91 a few weeks back. brought a top mount turbo kit with a side exit exhaust. its a tf035 turbo with the wastegate welded to use an external wastegate. obviously i have a fmic decat uprated fuel pum and all the mods needed to support an upgraded ecu to actually make it worth while having one. im looking for an ecu that kind of does all the pros and cons, best power gain, fuel economy etcalso im after one with launch control, built in turbo timer.. budget depends on what the ecu is capable of and what features its got, im looking for anywhere over the 200bhp mark. been told i can get 230 ish with the turbo set up and the mods ive got. just need a managent to run? ideas? options ? fire anything at me.. all advice appreciated. cheers. Quote Link to post Share on other sites
Sefton-EP91 Posted October 26, 2014 Share Posted October 26, 2014 Hi mate for the power figure your after your best bet would be an emange ecu.The ultimate version e has lauch control - not sure on turbo timer but timers can be picked up fairly cheap Or blue version which doesn't have lauch control but is a very cheap alternative and will do the bare minimum of what you need Hope this helps Quote Link to post Share on other sites
mikey4410 Posted October 26, 2014 Share Posted October 26, 2014 Yeah emanage is a possibility, very good units, hopefully soon I am buying one. Quote Link to post Share on other sites
_shaun_ Posted October 26, 2014 Share Posted October 26, 2014 I'd find the mapper you plan to use first and ask them. Emanages are tryed and tested. But things like das-teks are just as good if u can find the mapper. If U want launch control to for the emu. Turbo timer just but one seperate. For your power needs if wouldn't go any futher than a e-manage Quote Link to post Share on other sites
chad94 Posted October 27, 2014 Author Share Posted October 27, 2014 Thanks guys, looks like an emanage is my best bet.. Probably the ultimate if anything. Tuning developments are supposed to be good with the emanage. Have thought about a standalone ecu instead of a piggy back but they all seem very expensive when a buggy back can always do the same? Quote Link to post Share on other sites
Ollieh17 Posted October 27, 2014 Share Posted October 27, 2014 id say emanage bud.. 230 may be a bit of a struggle on a tf035 though bud Quote Link to post Share on other sites
Matt1878 Posted October 27, 2014 Share Posted October 27, 2014 On 10/26/2014 at 3:21 PM, chad94 said: hi guys, right.. as stated above im in need of some advice. i brought my ep91 a few weeks back. brought a top mount turbo kit with a side exit exhaust. its a tf035 turbo with the wastegate welded to use an external wastegate. obviously i have a fmic decat uprated fuel pum and all the mods needed to support an upgraded ecu to actually make it worth while having one. im looking for an ecu that kind of does all the pros and cons, best power gain, fuel economy etcalso im after one with launch control, built in turbo timer.. budget depends on what the ecu is capable of and what features its got, im looking for anywhere over the 200bhp mark. been told i can get 230 ish with the turbo set up and the mods ive got. just need a managent to run? ideas? options ? fire anything at me.. all advice appreciated. cheers.Right, after my eyes adjusted to your quil and ink style text, I'm currently running Emanage blue and it is a very good unit. Tried and tested on many starlets with a highly success rate. Just down to you where you get it mapped.. RDT, Tuning developments, race tech.. They all map this ecu. Quote Link to post Share on other sites
chad94 Posted October 27, 2014 Author Share Posted October 27, 2014 On 10/27/2014 at 10:29 AM, Ollieh17 said: id say emanage bud.. 230 may be a bit of a struggle on a tf035 though budI think I'm goin to go for the e manage ultimate as it has launch control. Any idea what power I'm likely to get from the tf035 mate? Quote Link to post Share on other sites
Ollieh17 Posted October 27, 2014 Share Posted October 27, 2014 On 10/27/2014 at 12:08 PM, chad94 said: I think I'm goin to go for the e manage ultimate as it has launch control. Any idea what power I'm likely to get from the tf035 mate?[/quoteI think haresign on here made good power on a tf035 at racetech 225 ish if i remember. When i had one and researched it looked like 210-220 at a push maxing the turbo was the norm. Im considering going back to a tf035 over a td04 now Quote Link to post Share on other sites
chad94 Posted October 27, 2014 Author Share Posted October 27, 2014 On 10/27/2014 at 12:18 PM, Ollieh17 said: On 10/27/2014 at 12:08 PM, chad94 said: I think I'm goin to go for the e manage ultimate as it has launch control. Any idea what power I'm likely to get from the tf035 mate?[/quoteI think haresign on here made good power on a tf035 at racetech 225 ish if i remember. When i had one and researched it looked like 210-220 at a push maxing the turbo was the norm. Im considering going back to a tf035 over a td04 now On 10/27/2014 at 3:42 PM, chad94 said: ame="Ollieh17" post="1054147" timestamp="1414412292]Tbf mate if I could get 120 I'd probably be fairly happy with that. Only running 150 now so it would be a decent jump Quote Link to post Share on other sites
