Jim* Posted October 27, 2014 Share Posted October 27, 2014 Car has developed a misfire under full boost randomly, not sure why, here is a video of what it is doing>http://youtu.be/p_ICf3b1tncAny ideas? Quote Link to post Share on other sites
turbominicooper Posted October 27, 2014 Share Posted October 27, 2014 check your plugs Quote Link to post Share on other sites
Jim* Posted October 27, 2014 Author Share Posted October 27, 2014 Had an ignition overhaul around 5 months ago Quote Link to post Share on other sites
turbominicooper Posted October 27, 2014 Share Posted October 27, 2014 5 months of covering how many miles? i would check them again to be sure Quote Link to post Share on other sites
sa15cr Posted October 27, 2014 Share Posted October 27, 2014 My glanza done the same and I changed plugs, plug leads, rotor arm and distributor and made no differences so then I changed fuel filter and run injector cleaner thru it and seems to be ok now Quote Link to post Share on other sites
Jim* Posted October 27, 2014 Author Share Posted October 27, 2014 Probably 3-4k Quote Link to post Share on other sites
mikey4410 Posted October 27, 2014 Share Posted October 27, 2014 I had a miss fire once on me starlet.was a corroded and split coil pack.I would be going back and checking dizzy cap and rotor arm and plugs also. Quote Link to post Share on other sites
Jim* Posted October 27, 2014 Author Share Posted October 27, 2014 I had a miss fire once on me starlet.was a corroded and split coil pack.I would be going back and checking dizzy cap and rotor arm and plugs also.As above though had an ignition overhaul within less than half a year Quote Link to post Share on other sites
Sefton-EP91 Posted October 27, 2014 Share Posted October 27, 2014 Mine done exactly the same and turned out to be leads. I understand you say you had ignition overhaul but does do exact same as mine did. Quote Link to post Share on other sites
Flaminsam Posted October 28, 2014 Share Posted October 28, 2014 Mine misfired like that, turned out to be the coil pack split. Mine started misfiring at about 8psi of boost then just got worse from there Quote Link to post Share on other sites
5e colin Posted October 28, 2014 Share Posted October 28, 2014 use multimeter to check the homes of the ignition leads Quote Link to post Share on other sites
Jim* Posted October 28, 2014 Author Share Posted October 28, 2014 What homes should they be? Where would you put the multimeter? Quote Link to post Share on other sites
5e colin Posted October 28, 2014 Share Posted October 28, 2014 pin on front and back i forgotten what homes they are sorry bean years sinds i last did that just check if there al near the same . Quote Link to post Share on other sites
ramses Posted October 31, 2014 Share Posted October 31, 2014 You have some durections about this:1)check ignition system2)check fuel system3)map sensor Quote Link to post Share on other sites
