dangeestarlet Posted October 30, 2014 Posted October 30, 2014 Hi , want to change my engine but don't really wanna take shafts out etc, can I remove it and leave the box in ? Thanks Quote
richardc9052 Posted October 30, 2014 Posted October 30, 2014 It's easier to leave shafts in and take out box and engine together. Just take the clip off the inner cup joint and unbolt either the ball joint or shocks from the hubs and the shaft and ball bearings should come out of the cups meaning they stay on the car ;) Quote
dangeestarlet Posted October 30, 2014 Author Posted October 30, 2014 Thought so il just do it and remove everything like I normally do, just thought it would of been quicker to save undoing bottom baljoints etc Quote
5e colin Posted October 30, 2014 Posted October 30, 2014 na if you have an engine hoist then its easy just undo all the crap an enginemount hold it level at hight with the crane wiggle the engine to drivers leg as far as you can then start hoisting upwards slowly pulling box and engine open top end of box and hearbox will open hold the box by hand and jack away Quote
5e colin Posted October 30, 2014 Posted October 30, 2014 jeeez are you guys greasmonkeys or not :p Quote
richardc9052 Posted October 30, 2014 Posted October 30, 2014 It's more awkward to take the gearbox out on its own than to lift the whole lot out so I'm guessing it's the same the other way around Quote
daniel_g Posted October 30, 2014 Posted October 30, 2014 jeeez are you guys greasmonkeys or not :pI like working efficiently and effectively, i find taking it all out in one works better Quote
5e colin Posted October 30, 2014 Posted October 30, 2014 ????? efficient it aint its way faster my way , then ripping out the box and all you need to jack up the car wheels of joints loose open the inner cv boots by that time the engine is alread coming out lets say 10 min more then that and its out i think it all lays with experience ha ha now im just pestering you guys lol :) Quote
_shaun_ Posted October 30, 2014 Posted October 30, 2014 Done it a few times and id say its Easier to take the lot out. Just leave the green cups in the gearbox and driveshafts in the hubs trying to wiggle the engine out with the gearbox still in place its fairly tight and its only a few extra bolts to remove the gearbox Quote
