Running an ep91 as a road rally car using 15ins x 6ins wheels Toyo Proxy tyres and having problems getting the rear wheels to lock on dry tarmac with the handbrake. Advice please what pads would be best?? Currently using standard apec pads
  • 4 weeks later...
Drums are normally the most torque you'll get for a given size (as the friction is all nearly at the outside diameter which in effect gives you a longer "lever") and as many drums are self-energising (which uses the rotation of the drum to increase the force on the shoe for "free", similar to how a servo creates extra line pressure using the "free" manifold vaccum).
In fact if drums didn't overheat so easily they would probably have remained the best bet for the front too - but they do overheat hence the disc brake.
Sort version - drums give you the most power for a one-off event like hitting the handbrake! :D
