My starlet is pretty much standard apart from a cat back . What is the cheapest (but safe) way to go td04 . I'v read the tuning guids on here and alot of topics but they all seem to be going td04 and aiming for big power gains And i just wondered if you can do it cheaper
seeing u are a gt boy just bolt on a td04 and run 6/7 psi it wil be ok if your on a budget just use topmount intercooler
i have an adaptor so you can use a td04 on a ct9 mani al you need to make is a downpipe and of you go
I thought so but have read different views on them preventing boost creep . Cheers for the help !
Td04 will be fine as the wastegate is big enough to control the boost
ct9 turbos creep badly with there smal penny and when there cracked
lucky the tdo4s dont really suffer like that and hardly ever creep like ct9s they hold steady boost much better
thats just my opinion on that :)
I've got a toyosports td04 kit sitting you can have for £220 delivered if its any use to you. Its obv not a very fancy kit but will get the job done ha
Mani decat td04 and water and oil lines. And a stock actuator and custom bracket. It came on my car when I bought it but I swapped it out for my current set up.
  • 3 weeks later...
