Charlie28 Posted December 2, 2014 Share Posted December 2, 2014 Is there anything i should check before i start up my forged engine. Obviously oil pressure, but what else? Cheers,Charlie Quote Link to post Share on other sites
Socks Posted December 2, 2014 Share Posted December 2, 2014 Disable efi. And crank the engine until the oil pressure light goes out. To prime the oil system. You don't want any part of it dry that's for sure. Chec for fuel leaks before starting. Start the engine run it for 30seconds. Checking all fuel system for leaks. Followed by cooling system. Then oil system. Don't load the engine up or Rev it aggressively. Quote Link to post Share on other sites
Charlie28 Posted December 2, 2014 Author Share Posted December 2, 2014 Ok bud, its not a newly built engine. Hopefully start her up this weekend Quote Link to post Share on other sites
daniel_g Posted December 2, 2014 Share Posted December 2, 2014 Also if its been sat for a while id take the rocker cover off and spray / pour new oil over the cams etc Quote Link to post Share on other sites
mikey4410 Posted December 2, 2014 Share Posted December 2, 2014 do not let it idle at all wen started first time either.needs to be minimum of 2.5 k for at least 10 mins Quote Link to post Share on other sites
Charlie28 Posted December 3, 2014 Author Share Posted December 3, 2014 do not let it idle at all wen started first time either.needs to be minimum of 2.5 k for at least 10 mins Socks said to not load the engine? Quote Link to post Share on other sites
mikey4410 Posted December 3, 2014 Share Posted December 3, 2014 I never said to load the engine dude.I said dont let it rev/idle low lol.huuuuge difference, Quote Link to post Share on other sites
Charlie28 Posted December 3, 2014 Author Share Posted December 3, 2014 I never said to load the engine dude.I said dont let it rev/idle low lol.huuuuge difference, Ah sorry bud, i misunderstood you! I'll make sure not to let the revs drop Quote Link to post Share on other sites
