Anyone experienced this?
Got to lunch time yesterday at Cadwell and I had some bearing noise, sure enough there was play. Before I called it a day I figured I'd try and nip the hub nut up, I did and the noise/play disappeared.
The pin was there, not sure if it was torqued up, one of the few parts of the car I haven't touched, it is now!
Maybe that was it?
Going to have a proper look around it before it's next outing anyway, thanks for the suggestions.
Put em to FT haha.
Actually quite common in cars, i see it quite a lot. Tell tale being the disc has a weird score round it if its been loose long enough.
