paddy Posted December 8, 2014 Posted December 8, 2014 I'm pretty sure my oil pump seal has gone, I'm getting a constant drip while running and replaced the crank seal and re sealed the sump the other day but still leaking. I ve ordered the I ring for the oil pump , does anyone have any advice on taking it off? Does it need to be resealed or anything when it goes back on? Quote
Ollieh17 Posted December 8, 2014 Posted December 8, 2014 just put some clean oil on the seal and press into the recess on the block Quote
aidanep71 Posted December 8, 2014 Posted December 8, 2014 And obviously put sealer on the pump itself when re fitting Quote
paddy Posted December 9, 2014 Author Posted December 9, 2014 Ok I took an old pump off my old engine and it came off easily, didn't look like it had any sealant on it. Is sump sealant ok to use? I'll just use a little oil or silicon grease on the seals Quote
patman Posted December 9, 2014 Posted December 9, 2014 (edited) Like this mate in link below 👍SECOND PICTURE WITH THE ORANGE SEALANThttps://uk.images.search.yahoo.com/search/images;_ylt=A9mSs2zeW4dUZygAS4dB4iA5?p=4efte+oil+pump&fr=&fr2=piv-web&psqn=2 Edited December 9, 2014 by patman Quote
Aamir Posted December 9, 2014 Posted December 9, 2014 Like this mate in link below SECOND PICTURE WITH THE ORANGE SEALANThttps://uk.images.search.yahoo.com/search/images;_ylt=A9mSs2zeW4dUZygAS4dB4iA5?p=4efte+oil+pump&fr=&fr2=piv-web&psqn=2 Yup^^^^ That pictures pretty much sums it all up Aamir Quote
Ollieh17 Posted December 9, 2014 Posted December 9, 2014 I only used a little bit on mine, hope i dont have to reseal Quote
paddy Posted December 12, 2014 Author Posted December 12, 2014 Very helpful thanks. Which sealant shall I use, would sump sealant be ok? Quote
Mk3 silver gt Posted December 12, 2014 Posted December 12, 2014 Yeah that grey stuff we used on the sump is fine, do you wanna do it on Sunday still? Quote
patman Posted December 13, 2014 Posted December 13, 2014 Make sure you use a brand new O RIng to mate what goes around the pump too 👍 Quote
